Wanted to say hi.
Wanted to say hi.
New to the 912 site. I have recently decided to start looking for a 912 to restore. Checking out the site for info on the 912 and what to look for. Currently have a 914.
Professor of Pending Projects
This is what I used when looking for mine:
1967 Porsche 912 Inspection
P (Stuttgart) 354000 355601
K (Osnabrück) 458101 - 463204
NUMBERS
Chassis serial number can be found in three places: driver's forward door post (placard), front latch panel (placard) and dash behind the knee pad (stamped into dash, knee pad must be removed to see).
Engine #:___________________________
Case #s: ___________________________
VIN: ______________________________
Transmission #: _______________________
Paint: _____________________________
OUTSIDE
Straightness of body (sight down sides)
Evenness of all door / panel gaps
Paint condition?
Evidence of repairs
Operation/fit of top and side curtains
Fit of top boot/tonneau
Condition / originality of wheels/hubcaps/tires (date stamp / manufacturer)
Presence and correctness of deco trim
Smoothness, detail of lower rocker panels
Smoothness, detail of wheel well arches
Reflectors in place
Type of bumpers/overriders/guards (correct?)
Apply "bondo-meter" to known rust areas, other areas around car (a good magnet works)
INSIDE PASSENGER COMPARTMENT
Steering wheel / horn ring correct?
Horn operational
Headlight flasher ("horn ring")
Operation / appearance of headlights, turn-signals, taillights
Operation / appearance of windshield wipers
Appearance of Seat bases
Operation of drivers' seat adjustment (fore and aft)
Operation of passenger seat adjustment (fore and aft)
Appearance of under-dash (overspray / wiring)
Appearance of Thresholds (lift rubber covers)
Appearance of Upholstery/seats
Appearance of Floor (Lift Rubber Mats)
Appearance of doors and door wells
Appearance of door undersides - rust?
Condition of "rolled edge" @ front of door opening
Sound of door closing
INSIDE LUGGAGE COMPARTMENT
Presence/appearance of body plaque
Appearance of hood underside (bent?)
Appearance of battery floor (bottom-tire out)
Appearance of battery floor (sides)
Appearance of battery and holddowns/cover
Presence / appearance of tool kit
Presence / appearance of jack and handle
Presence / appearance of spare tire (date stamp / manufacturer)
Appearance of matching number at hood hinge
Appearance of steering box
Appearance of wiring
Appearance of gas tank, sending unit, cap (date stamp)
INSIDE ENGINE COMPARTMENT
Appearance of matching number at deck lid
Correct engine for car?
Engine number: (#___________________)
Kind of carbs (correct?)
Kind of distributor (correct?) (009 points to incorrect parts... 022, 031 Good...)(#___________________)
Condition of oil on dipstick
Condition of engine wiring
General condition (other)
Type of muffler
UNDER THE CAR
Appearance of battery floor (probe)
Appearance of closing panels (front) (probe)
Appearance of frame struts (probe)
Appearance of fender braces (probe)
Appearance of closing panels (rear) (probe)
Appearance of longitudinal and jack-spurs (probe)
Appearance / operation of suspension & shocks
Appearance of rocker panels (bondo ?)
Condition of Suspension Pan
Appearance/Operation of heater boxes
Presence of oil leaks
Correct transmission for car? '67 902/1 Serial Number Range: 234001-238942 / '66 902/1 Serial Number Range: 221722-232164
DRIVING IMPRESSIONS
Oil /generator lights operational at key turn?
High beam light operational?
Turn signal indications correct? Auto-cancel?
Startup Oil Smoke?
Steering free play?
Engine smooth, quiet, powerful
Transmission smooth, quiet, adjusted properly
Excess slop in linkage?
Speedster gears? (tach / speedo relationship)
Tachometer smooth, accurate (Note redline, lag)
Speedometer/odometer
Oil Temp Gauge
Gas Gauge
Heater
NOTES
Check everything: chassis, body (especially the rocker panels under the doors). Also a #2 Philips head screwdriver: tap panels with the handle as fiberglass and metal have distinctive sounds. If a chassis panel sounds 'thin' (again distinctive), 'poke' it with the blade. A thin, rusty panel is easily penetrated. Suspension pan, chassis areas under rear torsion bar outer mounts, 'package shelf' and rear seat pans are subject to rust from the interior side.
Take a good magnet to test areas for bondo, a thin pointed screwdriver to check for rusted areas, LED light, camera, meter...
NUMBERS
OUTSIDE
Paint condition?
Evidence of repairs
Reflectors in place
Horn operational
Type of muffler
UNDER THE CAR
DRIVING IMPRESSIONS
Startup Oil Smoke?
Steering free play?
Oil Temp Gauge
Gas Gauge
Heater
NOTES
