912 Forum 1965-1969
My 1967 912 Build Thread
Old 02-04-2014, 11:59 AM
  #91
Wachuko
Professor of Pending Projects
Wachuko's Avatar
Forgot to mentioned this yesterday. Koni orange spray cans arrived... this is for painting the front struts to match the color of the rear Koni shocks.
More parts cleaned. These cleaned out excellent. Not sure if it was because of all the grease they were covered with. Now that they are cleaned, should I coat them with some black paint? Or will they stay fine without paint?
Old 02-04-2014, 04:18 PM
  #92
deactivateduser66
deactivateduser66's Avatar
How did I even miss this thread?! Looking great buddy. Sub'd!
Old 02-04-2014, 04:55 PM
  #93
Mr Michael B
Mr Michael B's Avatar
Originally Posted by Wachuko
...Also received a gift from Michael (thank you Sir! ) : vinyl seat covers and a new set of bushings for the torsion bar arms.
Hey cool! Enjoy installing those!
You know... They are fine unpainted, but I would say with them dismantled that far to put a coat of color on them too. That is at least how I would do it & I get the impression you are as car twisted as I am.
Old 02-04-2014, 05:57 PM
  #94
2mAn
2mAn's Avatar
just went through the entire thread so far. love all the pics and work you are going through. a rebuild for the normal garage guy! my style all the way. this thing will be so much fun when you are done, but Im sure you know you have a LONG way to go. Curious why you got a car from the PNW when you live in FL? much drier climate would've given you a lot less rust to deal with. Ive been looking for a 912 and I want one from CA so I would have minimal rust to deal with, because they ALL have some rust, the less you deal with the better. Either way, keep it up!!
Old 02-04-2014, 06:01 PM
  #95
Wachuko
Wachuko's Avatar
It was a local purchase. Previous owner had moved recently. I had been looking for one for a long time... And for whatever reason I was not lucky enough to find an amazing car for 1,500.00 . All that I could find were cars in a bad condition and people wanting top dollar for them. So, at the time, this one looked great. I was not expecting to have to spend so much on the engine...but that is another story. Just thankful that Peter gave me that case...
Old 02-05-2014, 02:08 AM
  #96
Amber Gramps
Amber Gramps's Avatar
Jaime, I think I saw an entire row of 912 engines today. They were either that or 356 engines...either way, I'm here to help, with whatever I can now that I've been made aware of what you are up to.
Old 02-05-2014, 07:18 AM
  #97
Wachuko
Wachuko's Avatar
Thumbs up
Thank you for the offer. I am going to go tomorrow to a local shop (Troy Motorsports) and talk to Sid. Taking the case with me to see if they can fix it locally. That is currently the most important task right now. Followed by buying a crankshaft.
AA is out of budget conscious piston and cylinder kits...so I have to wait on those. But no hurry on those until the core components are done...
Found a company that does chrome plating locally, I will try to use my lunch break to stop by and see if they can do the horn ring.
Old 02-07-2014, 01:17 AM
  #98
Wachuko
Wachuko's Avatar
Horn leather came in today. Also got a callback from the local plating shop saying that they can chrome the ring.
Old 02-07-2014, 12:48 PM
  #99
Wachuko
Wachuko's Avatar
Cool
Updated list...
(2) [901.628.311.01] Front Windshield Wiper Blade, 13" Silver - Ordered
(2) Side Vent Window Hardware 64454255800 - Ordered Installed!
(2) Washer for side vent window hardware 91154255648 - NLA, using the existing ones
(2) Coat Hooks - these are brittle and need replacement
(2) Hood Shocks 95951133300 - Ordered - Installed!
(1) Engine Lid Shock 90151233120 - Ordered - Installed!
(2) Rear Koni Shock Absorber - car came with Boge but I like the looks of those orange Koni shocks - Ordered
(2) Front Koni Inserts for Boge struts - Also, to document the correct orange color as per email from Koni. They use: Plasti-Kote 200 Chevrolet Orange Engine Enamel
(2) Rear suspension bushing - outter 901 333 195 00 (might look for something better than factory for both inner and outer bushings, like from Elephant Racing) - Got them - a gift from Michael
(2) Rear suspension bushing - inner - 644 333 131 00 - Got them - a gift from Michael
(2) Tie Rod End (Ball Joints) 911 347 322 04 - Ordered
(4) Stabilizer bar bushings 901 333 793 01
(3) [900.087.011.02] Hood Damper Pin - Ordered
All seals... need to finish the list... just listing the most critical ones to avoid water getting into the car...
(1) Windshield Rubber Seal 91154122503
(1) Front Hood Seal 90151190102
(2) Door Seal 91153109503
(1) Rear Window Seal 91154522500
(2) Felt Window Channel 911-542-905-00 - Ordered
(2) Plastic cover for window crank. I have it, but they marked it when removing it... 901 542 472 20
(1 of each) L and R Tail Light Lens... the ones in the car have hairline cracks and I see that you can get just the lens to replace... great.
(1) User Manual WKD-460-520 - Ordered. 1967 manual was still available from Porsche... and cheaper from them than other vendors...and I need to know what all the levers and lights mean...
Sheet Metal:
(1) Full Width Parcel Shelf Sheet Metal Replacement SMC.501.955.20
(1) Outer Rocker Panel – Right Side Metal Replacement SIC-503-402-04
(1) Front Floor Pan Half – Metal Replacement- Ordered got it from Restoration Design
(1) Rear Seat Floor, Right Side Metal Replacement SMC.901.501.070.00
Engine:
(1) Carb Plug on top left side in the air filter housing 616 108 938 00 - Ordered
(4) Missing one bolt in the carb air cleaner housing N 010 354 1 - Ordered
(2) Exhaust clamp 369 54 109 - Ordered
(1) Need to check condition when I remove it, but just in case - Right Side Heat Exchanger 616211 004 01
(1) Engine Cylinder Head Gasket Set 616-100-184-03-M17 - Ordered
(1) Engine Crankcase Gasket Set 616-101-901-01-M17 - Ordered
(8) Oil Push Rod Tubes 616.105.231.00 - Ordered
(1) Oil Breather Reservoir 616.107.079.03 - I notices small pin-hole size holes in the top area, near the neck where the cap is... not sure if that can be repaired, I wll try to weld it with a bronze rod... Most likely the rest of the interior is in bad shape... (cool link on cleaning these, thought I would share Refinishing Oil Breather
(1) Oil Cooler... seems there are better alternatives made out of aluminum and with better cooling efficiency. - Aluminum Oil Cooler Ordered!
(1) Exhaust Stud 90006100501- Ordered
(1) Carburetor Rubber Sleeve 99970210150 - Ordered
(2) Rubber Sleeve in Heads 99970204750 - Ordered
(10) Washer Carburetor Bolts N0115247 - Ordered
(40) Pan Head Screws for Engine Tin 90001406502 - Ordered
(4) Connecting Rod Bushing 901-103-131-01 - Ordered
(8) Connecting Rod Nuts 502-03-114 - Ordered
(1 ) Piston and cylinder kit - 86mm Big Bore Kit with Biral Cylinders & JE Forged Pistons from AA Performance Products Ordered
(1) Crankshaft - Went with one from AA - 74mm Porsche 356/912 Crankshaft 4340 Chromoly Billet - Ordered
(1) Main Bearing Set - Standard case from Peter, new crankshaft so Standard bearings it is - Ordered
(1) Gland Nut with Pilot Bearing - Flywheel to Crankshaft 616-102-025-01-M260 - Ordered
(2) [ 539.06.116] Fan Shroud Rubber Plug - Ordered
(1) [616.108.938.00] Oval Wire Mesh Filter Plug - Ordered
(1) [999.211.004.00] Oil Cap, 912 (68-69) (wanted the cadmium plated finish) - Ordered
(1) [644.701.009.00] Oil Filter Decal, Fram - for when I paint the oil filter housing - Ordered
(1) [644.701.001.00] Valve Clearance Decal - Ordered
(1) Oil Strainer Sump Screen 616-101-380-00 - Ordered
(1) Oil line to oil filter housing 616-07-818 - Ordered
(1) Oil line to oil filter housing 539-07-826 - Ordered
(2) Cylinder Head Rubber Grommet for Oil Breather Tube 999-702-047-50 - Ordered
(1) Oil Pressure Relief Valve (Piston) 616-107-511-00 - Ordered
(1) Oil Sump Cover Kit - Ordered
(1) Full Flow Oil Filter kit
Rubber Boot Covers
(1) Outside Shifter Tunnel 901 424 293 00 - Ordered
(1) Inside Shifter Tunnel 901 424 292 01 - Ordered
(2) On each side of the Shifter Tunnel 911 423 593 01 - Ordered
(1) Clutch cable 695 423 922 00 - Ordered
(4) CVJ Rubber Boot covers - Ordered
(4) CVJ Gaskets - Ordered
(1 kit) - [644.109.382.00] Engine Boot Set for electrical connectors in the engine - Ordered
Now to wait for all of what has been ordered to arrive...
Old 02-07-2014, 07:45 PM
  #100
Wachuko
Wachuko's Avatar
A few parts came in today...
Old 02-08-2014, 09:26 PM
  #101
Wachuko
Wachuko's Avatar
Cool
Cleaned the case... removed the studs for the sump cover (a few were missing, one was longer, and new studs are coming anyway), took it apart to clean the inside, sprayed WD-40 in all holes to make sure there was no dirt in the oil passages... Put it back together and back in the stand...
Rear wheel spacers came in (see previous post), got them cleaned and tested... studs are long enough, so all good to go.
Replaced the bleeder valves on the calipers
Also finished cleaning all the brake parts...
Grease, rubber boots, and bearing packing tool came in so I am going to rebuild now the drive shafts and put them aside for when it is time to install them...
Replaced the seals on the rear brake covers
Also got the carpet out... I am going to try to make that part myself... some sheet metal, some wood to use as template, a BFH....worst case scenario, I can always take it to someone to fix it...
Old 02-09-2014, 01:04 AM
  #102
Wachuko
Wachuko's Avatar
Cool
A few more of the rust... both seat bottoms will need to be repaired.
Painted these parts as well...
Old 02-09-2014, 01:37 AM
  #103
FlatSix911
FlatSix911's Avatar
I would recommend coating the inside of the tub with POR-15 after the rust repair is completed.
Old 02-09-2014, 01:44 AM
  #104
Wachuko
Wachuko's Avatar
Thumbs up
I will add POR-15 to the list of items to buy. Thanks!
Seat bottoms, rear parcel shelf, front half floor pan (this one I ordered already), and right outer rocker panel need to be replace/repaired.
Old 02-09-2014, 07:20 PM
  #105
Wachuko
Wachuko's Avatar
A few more photos of finished parts...
Front calipers
Rear stuff
Cleaned, degreased, and resprayed the rear wheel well... When the car goes for a respray, I will remove everything again, but for now I want this to looks good and be clean and protected.
Also got a parts cleaner on special... not bad for 76.00
Quick Reply: My 1967 912 Build Thread
