My 1967 912 Build Thread - Page 5 - Rennlist Discussion Forums
Thread Tools Search this Thread
Old 01-26-2014, 11:25 PM   #61
FlatSix911
FlatSix911's Avatar
Well done ... keep up the great work!
FlatSix911 is offline   Reply With Quote
Old 01-26-2014, 11:47 PM   #62
Wachuko
Professor of Pending Projects
Wachuko's Avatar
Thumbs up
Quote:
Originally Posted by Mr Michael B View Post
"...Plan is to clean all the wheel well, and make it look nice. Refresh those bushings as well... got to look for some better bushings without going solid... those red polyurethane bushings... if anyone knows where they sell those, chime in please..."
I believe I have a set of black poly bushings for the rear. They came with the car. I have been told it will take an act of congress to get them on - so I went with factory rubber. You want? I am not using.
Another challenge? Bring it on! I will PM you my address.
Wachuko is offline   Reply With Quote
Old 01-28-2014, 10:18 AM   #63
Wachuko
Wachuko's Avatar
Cool
Talked to Walt at Competition Engineering ( http://www.competitioneng.com/contact.htm ) to see if they could find blanks that can be cut to 3rd Oversize... and also asked him about taking the case back to accepting standard bearings... it can be done, but not cheap (about US$1,500.00)...
Got Walt's reply later yesterday... not good news... They do not have any bearings this size and the guy that makes them has never made any that big...
A fellow forum member on the 912bbs.org, Peter Graham, gave me a case! On the case that Peter has so kindly offered, the broken bearing tangs can be fixed. But until a case is torqued together and measured with a bore gauge, it’s all guess work. Case is on its way to me via FedEx. Here is a photo of the damage on that one:
I also have an appointment with Sid (Troy Motorsports here in Orlando) on Wednesday afternoon...
Calling a few other vendors, not completely given up in trying to find a bearing set... but also working on plan C (fix Peter's case, Thank you Peter!!!)... and plan D (finding something standard that does not require additional work, but buying parts remotely via eBay is always a gamble)...
I was told that these engines are matched... meaning, all three case pieces are done to fit with each other. In most cases front cover pieces might work with a different case, but not always. First step was checking the third piece, front cover, that I have. Happy to find that the bearing there (I believe it is bearing #4) is standard. So the front case cover was not machined. As to fitting a different case, well, I will not know that until I present them together and see if both the camshaft and crankshaft align perfectly.
The orange book has been great, great to have seen it as one of the recommended books in the sticky section of this forum. So for those reading this and do not have it, get it!
Pages 222-225 provides the dimensions for the bearings... I also have the pdf version of the workshop manual, but nothing beats having a real book in front. I need to print out the workshop manual.
Old 01-28-2014, 10:30 AM   #64
Wachuko
Wachuko's Avatar
I have to take just a moment to say something about what has happened here... I have had strangers letting me borrow DVDs that you can't even find for purchase! Others offering parts (from small parts, seat covers, a case!) for free, just to help out. Those that have shared, with patience, their knowledge so that I can understand what I am doing, what I am looking at, and what options I have.
Guys, I am really touched by your kindness. I just want to say thank you to all of you. You have placed a great responsibility on my shoulder to find ways to pay all this forward. Thank you, thank you, thank you!!
Old 01-28-2014, 10:09 PM   #65
ultra912
User
ultra912's Avatar
Peter is a STAND UP guy for sure. He's helped me many times.
ultra912 is offline   Reply With Quote
Old 01-29-2014, 11:14 AM   #66
Wachuko
Wachuko's Avatar
Took the horn assembly out of the steering wheel. Easy enough. Just hold the steering wheel and do a 1/4 turn counterclockwise of the horn and out it comes.
What is the correct way to make it look like new again? Are these painted or powdercoated? Satin gloss, correct?
The leather insert, several sources that have them. Any one better than the other?
Sierra Madre Collections - Hockey Puck Button Leather Center
Stoddard - Leather center
Ebay - 912 Horn Button Leather
Someone here in the forum?
Old 01-30-2014, 08:23 AM   #67
Wachuko
Wachuko's Avatar
Plan to get Koni shocks for rear and front. For the front, since it currently has Boge, I plan to paint the front strut outer part Koni orange. From searching on this, found that this is the color Koni uses on their shocks: Plasti-Kote 200 Chevrolet Orange Engine Enamel
Also got these stickers for the shock absorber strut outer part:
And ordered some silver caliper paint to protect the calipers once I clean them well.
Old 01-30-2014, 11:40 AM   #68
Mr Michael B
Mr Michael B's Avatar
Quote:
Hmmm.. I sent my wheel to Bruce Crawford. He is the National expert on all things steering wheel. www.hardwoodclassicsltd.com
Perhaps a photo will give you enough detail
Mr Michael B is offline   Reply With Quote
Old 01-30-2014, 11:58 AM   #69
Wachuko
Wachuko's Avatar
Thumbs up
I will soda blast the steering wheel metal areas and try paint. I ordered the leather center piece from eBay.
The missing piece is that chromed ring. Sierra Madre has it on back order. A hefty 156.00 for that ring. The one in mine is in need of re-chroming to be able to use it again... not sure what the cost of that would be. And it really needs to be chromed to look right. No amount of polishing will make it look like the one in yours because it is made out of brass .
Thank you for the photo. I will use it as a reference when doing mine.
Old 01-31-2014, 12:19 AM   #70
ultra912
User
ultra912's Avatar
Jay Leno recommends this chrome spray for small items. I'll find the video.
Old 01-31-2014, 10:14 AM   #71
Wachuko
Wachuko's Avatar
Thumbs up
Quote:
That would be perfect for something like the interior housing of the lights Same paint technique used for mirrors and then you clear coat the part. Pretty cool. I will look for where they sell that (there has to be an option to ordering from Europe).
I would still like to have the ring chrome plated. I will find a local plating shop to take the ring. Should not be much for chrome plating it.
Old 01-31-2014, 09:48 PM   #72
Wachuko
Wachuko's Avatar
Cool
Look at what came in today!!! Peter, you sure can pack a case to avoid any damage to it!!!
I had to take photos to be able to put it back in the box when/if I send it to Walt.
Engine stand also came in today...
I hope this can be fixed easily:
One side:
The other side:
And a few more photos of the case from Peter:
Back together...
The case's condition is so much better than mine... comparing the two I can see now how beat up and tired mine is...
Something that Sid from Troy Motorsport highlighted when I went to see him with my parts, was that the base plate for the oil cooler had been welded.... well now I can clearly see the difference!!
Case from Peter:
Mine:
I need to see if Sid can fix the case locally or if I send it to Walt. I will decide based on my next visit to Sid. While I was at his shop he showed me what the heads done looked like... also explained a few things that I were still not clear to me. Funny as we were talking about the heads and I made the comment that the valves were only like 25.00... he just laughed... that is when I learned the difference between ATE valves and AE...
Anyhow... that is all that I have for now. Family is demanding some quality time... movie night, so we are sitting in the family room with some pop-corn and ice cream to watch a movie together... back with more tomorrow!!
Old 01-31-2014, 10:06 PM   #73
ultra912
User
ultra912's Avatar
Enjoy
Old 02-01-2014, 11:04 AM   #74
lowpue
lowpue's Avatar
Hey, restoring the horn was one of the first things I did. Took apart the horn and I just used some etching primer and rustoleum....Actually worked pretty good. Then I found some foam that was probably a quarter inch or so thick and replaced the old crumbling foam. I simply used black shoe polish on the horn leather and OMG...it looked great. The one thing I am not happy with is I used spray on chrome....while it looks much better, I would definitely chrome it. At some point I will chrome it but its a low priority right now. If I get out to my storage unit I will take a picture and post.
lowpue is offline   Reply With Quote
Old 02-01-2014, 11:16 AM   #75
Wachuko
Wachuko's Avatar
http://www.youtube.com/watch?v=A-1cTpSZ1l8
Found the kit for this... US$289.00
http://www.alsacorp.com/products/chromefx/
Related Topics
Thread Thread Starter Forum Replies Last Post
912 Outlaw project noboco 912 Forum 10 02-10-2017 12:12 PM
So I went to Stuttgart.. Gregster Rennlist Canada 53 03-07-2016 01:16 PM
Projects on our (new to us) 1967 912-6 jerhofer 911 Forum 306 10-27-2015 11:09 PM
Complete Emissions Exhaust and Air Pump from 1983 911SC jerhofer Parts Marketplace 1 07-27-2015 04:36 PM
Tags
67, 911, 912, biggest, build, compression, engine, lift, orange, original, piston, porsche, put, table, test, thread, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 1998 - 2015 Rennlist.com
  • Ask a Question
What's your question?
Send
