Steering wheel removal
Hello Again
I shouldn't be in this forum as i have a 964 but i have a friend who has a lovely 912.
The steering wheel is slightly off centre so he came down to my garage for me to straighten but i didnt want to damage the horn centre and force it so i wonder if you guys could tell me how to remove the steering wheel please.
I did a search like i always do but couldn't find anything relating to my problem.
Cheers
Jeff
Cheers
Jeff
Poseur
To remove the steering wheel you should turn the central horn ring a bit to the left. About 15 degrees will do it. Then it should lift straight off,--mind the wires (for the horn).
Then take a large (maybe 27mm) socket wrench to it. Hold the wheel with one hand and loosen the nut with a 1/2 in drive with the other. What I like to do is to do it in a long driveway. Make sure that you know what driving straight ahead is with the steering wheel and place the steering wheel accordingly. Once you know it's good,--torque it down good. Make sure the horn wires are clear, and then twist back on the horn portion of the wheel.
If you're talking about a 912E then you need to pop off the horn from the wheel. There are 4 little attach points for that steering wheel. Reinstalling it is just by aligning the horn section, and then rap firmly at each of the corners to reinstall it.
