1984 Porsche 911 Turbo Look
My 911 Turbo look came with (F) 205/55/16 and (R) 225/50/16 but I want to
upsize my tires to (F) 225/50/16 and (R) 245/45/16.
My question is do I have to also change my rims too? If I want to upsize.
Thanks in advanced
Thanks in advanced
Rims for Porsche 911 1984
according to this website: https://www.wheel-size.com/size/pors...all-trims-usdm
- Bolt pattern 5x130
- Diameter: 16.0'';
- Width (inches): 6.5;
- Offset (mm): 20.
Run 245/50/16's, This way your tires are same Closer Circumference Front & Rear, I've Ran these tires on many 16's over the years, Great tire, Look at "Specs" & you can see Exact Circumstances. 225/55 or 215/55 Fronts. Your choice...
https://www.tirerack.com/tires/tires...omCompare1=yes
