911 Turbo (930) Forum 1975-1989
83 930 will not run
Old 04-17-2015, 07:58 PM
jacoviii
8th Gear
jacoviii's Avatar
Default 83 930 will not run
Ok so I have a 83 930 that my dad left me. It had not been started in 15 years. Well I got it started last year but it would not run long like maybe 30 - 40 sec. I found the front fuel pump was bad. I just replaced it and cleaned the strainer. Now it will almost start and run rough for like 3 sec. but not stay running. I can do this like 3 times then it just cranks. When I turn the key I do not hear the fuel pumps run but after it runs for the 3sec. or so and dies I hear the pumps for a sec.
What should i look for?
Old 04-19-2015, 02:18 AM
GRINBOB
GRINBOB's Avatar
I would clean the fuel system from one end to the other. Make sure that the filter in the gas tank is not clogged. I would remove the fuel tank and have it cleaned. Start with new gas and filter. Good luck!
Old 04-27-2015, 12:23 AM
jacoviii
8th Gear
jacoviii's Avatar
Got it running the metering plate was gummed up. I still need to take the gas tank out and clean it better.
Old 06-20-2023, 03:33 AM
imortalo8
imortalo8's Avatar
Long story short guys, car got fixed and running perfectly. Warm up adjustment when cold is what it needed. Cars is an absolute beast now. Thanks for all advice and help guys! Very much appreciated.
Quick Reply: 83 930 will not run
