930 interior work
930 interior work
I've decided to take on a bit of a winter project. I'm going to be replacing my dash pad, headliner, rear deck, sun roof cables, carpeting and door panels this winter.
I'm going to be doing the work myself. I have a nice heated shop to get all the work done.
I'll post more pictures when I get the car moved into the shop and get the windows out
Mark 86-89 no windshield removal is needed to remove the dash. I did it twice on mine. The dash has 7 bolts with 8mm nuts(iirc). Easier with the steering wheel off and gauges pushed out . You will need a long adapter(better with an 8mm magnetic socket) that can hold an 8mm nut. Three of the nuts will be removed through the front trunk(using the long adapter)...oh and a small ratchet and open wrench with a ratcheting end...again in 8mm.
Would be really interested to learn from your experience. I am also debating what to do about my 82 930's leather dash as the leather has contracted quite a bit over time. Are you going to maintain the old leather or replace?
Value of 1977 Porsche 930 Turbo?
I have a 1977 Porsche 930 Turbo. I am curious of it's value.
It has 24,000 original miles (yes only 24,000 original miles).
Engine was completely rebuilt at 23,500 miles. -for age (car is over 30 years old), no other reason.
Paint and interior are in excellent museum quality.
Ordered special without sunroof from factory.
Everything on car is original, all options were put on car when ordered (full leather, etc).
Disc breaks, transmission and pretty much everything else on car has been either rebuilt to new or checked to make sure it is in 100% perfect condition.
Car is truly a museum piece, never been raced or driven in rain.
Guards red w/ black trim. Full black leather interior.
Just curious what it is worth.
thanks!
Used Car Parts
thanks!
Used Car Parts
I have a 1977 Porsche 930 Turbo. I am curious of it's value. It has 24,000 original miles (yes only 24,000 original miles). Engine was completely rebuilt at 23,500 miles. -for age (car is over 30 years old), no other reason. Paint and interior are in excellent museum quality. Ordered special without sunroof from factory. Everything on car is original, all options were put on car when ordered (full leather, etc). Disc breaks, transmission and pretty much everything else on car has been either rebuilt to new or checked to make sure it is in 100% perfect condition. Car is truly a museum piece, never been raced or driven in rain. Guards red w/ black trim. Full black leather interior. Just curious what it is worth. thanks! Used Car Parts
Also what you could do is post on eBay with a very high reserve and see what the car goes for. I would say it is a 120k plus car may be even on the low side. if it is stock and is truly a museum quality car.
