best way to clean fuchs rims?
Technical Specialist
Lifetime Member
Lifetime Member
You may want to check out the wheel care articles at <a href="http://www.carcareonline.com." target="_blank">www.carcareonline.com.</a> On my BBS rims, after using P21S Finish Restorer for shine, I use a coat of carnauba wax for protection.
back several years ago, I clean up a set of Fuchs with a product called micromesh. It is used to polish airplane windshields. The product is basically a set a strips of cloth with grits ranging from 400 to 6000 if I remember correctly. When I was finished, the shine was absoulutely brilliant. I got the info from the archives then so if the archives go back 5 years or so, there was a lot of discussion about the product and where to get it back then. Good luck.
