911 Turbo (930) Forum 1975-1989
Tire Sizes on 17X10?
Old 08-09-2005, 07:09 PM
Earlierapex
Earlierapex's Avatar
Default Tire Sizes on 17X10?
What is the best tire size to use on a 17X10 on a 930? 275 or 285? Will they fit the 10 inch? I assume a 315 is too big?
Thanks.
-dc
Old 08-09-2005, 09:26 PM
C2 Turbo
C2 Turbo's Avatar
285 !
Old 08-10-2005, 12:29 AM
Sameer
Sameer's Avatar
On my Ruf 17 inch speedlines I got:
235/40/17-9inch
285/40/17-10inch
Old 08-31-2005, 03:22 PM
Earlierapex
Sameer,
Are the 285s too tall? Everything fits no problem? Thank you.
-dc
Old 08-31-2005, 05:32 PM
WERK-I
WERK-I's Avatar
Derick,
You can get Kumho Ecsta MX's in 285's that will fit 17x10" rims. Just remember when you purchase the fronts, get fronts with the same diameter(or as close as possible) as the rears or your car's existing rake will be thrown off. For instance, the diameter of the 285/40 YR17 is 26". In which case, on an 17x8" rim, you can fill with a 235 or 245(285/45 YR17) which has a diameter of 25.8". If you went with a 245/40 YR17, the diameter is 24.8". Over an inch shorter!! A decrease in the front's ride height by over 1/2". Of course, maybe you enjoy adjusting your ride height.
I used the TireRack.com web site for the numbers provided.
http://www.tirerack.com/tires/Spec.j...model=ECSTA+MX
Just remember, use the charts provided by the manufacturer to determine what they recommend for the rim size vs. tire size. Some tire manufacturers will only recommend 275's for a 10" rim.
Old 08-31-2005, 05:48 PM
Earlierapex
Very good advice. Thank you!
Looks like a 245/45/17 285/40/17 will work pretty well. Only 0.3 inches off.
-dc
Old 08-31-2005, 07:48 PM
IamSMC
IamSMC's Avatar
-dc
What will you be running in the front?
Old 09-01-2005, 12:16 AM
Sameer
Sameer's Avatar
Can we go 295 with 10ich wide 17 inch rims?
Old 09-01-2005, 01:12 AM
C2 Turbo
C2 Turbo's Avatar
The tire co's might recommend 295 for a 10" wheel but it really belongs on a 10.5" wheel.
Old 09-01-2005, 02:36 AM
Sameer
Sameer's Avatar
Yasir,
Any disadvantages especially at high speeds going 295 on 10inch wide?
Old 09-01-2005, 11:37 AM
Earlierapex
245/45/17 on 9X17.
-dc
Quick Reply: Tire Sizes on 17X10?
