911 Forum 1964-1989
1981 Euro 911sc exhaust upgrade?
Old 02-11-2017, 12:13 PM
James Ruggere
2nd Gear
James Ruggere's Avatar
Default 1981 Euro 911sc exhaust upgrade?
I am interested in doing exhaust work on my 1981 911sc Euro. I want to improve the performance and sound. The car has had the entire heating system (exchangers, blower and tubes) removed. I have a set of Bursch tuned headers and the crossover oil lines to correctly install the headers. Here is my question: should I install Supertrapp straight out mufflers or should I use a dual-in dual out stock fit type Dansk muffler? Which is best? OR should I just keep it stock? I have even heard of guys using a Magnaflow muffler set up from a Camaro (it fits). Any comments will be appreciated.
Old 02-11-2017, 08:27 PM
cool whip
cool whip's Avatar
I, as well, would like to know about an affordable upgrade from stock.
Old 02-11-2017, 09:02 PM
tpd83911
tpd83911's Avatar
James, I recently upgraded my 83 sc to SSI heat exchangers and a M & K dual-in, single-out muffler. Sourced both from Pelican where there is good info about options. The exhaust-note bears no resemblance to stock- certainly a bit louder but a lot more "growl". I like it a lot and there is a claimed increase in lower-end torque with the SSI set-up. It does feel like it has a bit more zip. I had added front oil-cooler so also needed oil cross-over lines. This has been a great upgrade that I wish I had done ten years prior. SSIs about $1675 and M&K $795 so it all depends on definition of affordable. If I drive 20 more years or so it annualizes out to be affordable
As an aside I have the entire original heat-exchangers, cats, muffler in decent shape and a M&K cat bypass. PM if interested in any of that stuff.
Old 02-15-2017, 11:41 PM
theiceman
Team Owner
theiceman's Avatar
Received 1,025 Likes on 729 Posts
" best" is such a subjective term.
I have SSIs to go on and a dansk non sport 2-1 muffler.
I have no desire to sound loud or obnoxious The stock sound of an air cooled is sweet enough with the extra grunt of the SSI
Old 02-16-2017, 05:00 PM
cool whip
cool whip's Avatar
I really want to avoid being loud and obnoxious, thank-you!
Old 02-16-2017, 05:09 PM
r911
Anti-Cupholder League
r911's Avatar
if this Euro car has the same exhaust as the '73 then you cannot increase the performance with just other exhaust trinkets - SSIs might be lighter tho; or use Ti$$$
You can drop a few 10 thousand dollar bills on motor hotrods and a tuned exhaust....
if you seek a slightly louder sound at the same performance level, then there are various options - in order:
stock
various others with no or little resonance
Monty
Monty with cowhorns
sports straight outlets (many can be capped to reduce the SPL and convert it back to stock)
why not lose some wt. back there with an M&K or Monty?
Old 02-21-2017, 12:45 PM
John@Fabspeed
Basic Sponsor
John@Fabspeed's Avatar
Hello James, nice car you have there! We have specializing in Porsche sound/performance for near 25 years, and R&D exhaust systems right here in Fort Washington, PA...a stones throw from you in Reading. You should come stop by! Would love to give you a tour of our facility and go over some options with you to meet the goals you have for your SC
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
Old 02-21-2017, 01:52 PM
tdrimer
tdrimer's Avatar
Best thing i ever did to one of my Porsches was a fabspeed exhaust.
Old 02-22-2017, 10:20 AM
Bill Verburg
Bill Verburg's Avatar
There were 3 different Euro motors in 1981
930/10 no cat, 9.8cr
930/09 mit cat, 8.6cr
930/19 same as /09 but for sportmatic.
The main benefit of headers is two fold
flow increase
exhaust scavenging where the reflected sonic signals in the exhaust arrive at overlap to suck additional fresh charge into the cylinder
any muffler pretty much negates any scavenging effect and w/o cam over lap there will be little effect anyway, The cams in a stock SC or 3.2 Carrera have zero overlap(it's actually -1.5° by contrast an early S will have 57° of overlap ) So pretty much the main benefit of an exhaust mod on a stock SC/Carrera is to increase flow. To that end the stock exhaust on a 930/10 is actually not too bad, these cars have a resonator where the other versions have catalytic converters. SSI will flow better(depending on muffler used) but not a whole lot better and only in the upper reaches of the rev range.
Many want better sound, which is usually louder too
here is a stock SC/Carrera muffler
you can mod it like this for sound or but a DAnsk /Monty sport muffler and avois the work.
Quick Reply: 1981 Euro 911sc exhaust upgrade?
