911 Forum 1964-1989
9m11RS Part 1: Regeneration
Old 09-27-2016, 03:52 PM
09mageec
09mageec's Avatar
Originally Posted by NineMeister
The zinc galvanising is a sacrificial anode that erodes to protect the steel once electrolytic corrosion starts, usually due to the presence of water which has penetrated the under body paint or sealant. Since the sealant is bonded to the zinc, once the zinc starts to erode away the sealant forms a hollow cavity that collects more water which continues the corrosion and eventually begins attacking the steel. Some areas (like the front edge of the kidney bowls) are masked from the factory sealant gun, hence they have nominal paint coverage and begin erosion/corrosion earlier in the life of the car.
VERY interesting, and very cool as well. Never knew, in depth, how galvanization actually worked, thanks!
Old 09-27-2016, 04:04 PM
r911
Anti-Cupholder League
r911's Avatar
kidney bowls?
Old 09-27-2016, 05:10 PM
NineMeister
NineMeister's Avatar
Originally Posted by r911
kidney bowls?
Kidney Bowl - the reinforcement panel at the back edge of the sill, behind the quarter panel/B-post. This is the later, stronger version freshly welded onto the right inner sill, the outer sill yet to be fitted over the front section.
Old 09-28-2016, 11:24 AM
NineMeister
Only one way to tackle a job like this: one piece at a time. Our fabricator Oggy started work on the right rear corner, replacing the entire inner wing and inner sill with a new factory panels. Don't worry, I have more photos of the left side during the repair process to show what lies beneath.
Old 09-28-2016, 11:28 AM
NineMeister
Late model kidney bowl/jacking point next, fully welding the joints underneath first. This is what it looks like under the outer sill. Note the concertina heater tube (silencer) inside the inner sill to floor cavity.
Old 09-28-2016, 11:34 AM
09mageec
09mageec's Avatar
Some fine work here
Old 09-28-2016, 11:35 AM
NineMeister
New rear panel next before it got a whole lot more scary....
Old 09-28-2016, 04:05 PM
r911
r911's Avatar
will you do anything to stiffen the unit body beyond stock?
Old 09-28-2016, 07:09 PM
NineMeister
You mean, apart from welding in full steel panels where there was once iron oxide? ;-)
The kidney bowls shown in the previous photos are the late 3.2 Carrera version which stiffen up the sill to inner quarter section and some subtle seam welding in critical areas. That's all.
Old 09-28-2016, 07:19 PM
NineMeister
Since both inner wings were so badly repaired in the previous "restoration" it was an easy decision to opt for the dual battery box version of the original 2.7RS. With the new right panel in place, all of a sudden the shell is starts to look like a real 911 again.
Old 09-28-2016, 08:05 PM
r911
r911's Avatar
TRE in Calif. has done a number of things to stiffen the unit bodies on these cars. Also, a guy named Tyson (Schmidt??) has worked on some stiffening for the front part of the shell - IIRC, he was never sure how feasible that is.
Those are the types of things I am curious about. Especially since so much work is being done already.
Old 09-29-2016, 02:44 AM
Amber Gramps
Amber Gramps's Avatar
Rumor has it Tyson was Jack Olsen's secret weapon
Are the panels sourced from Dansk? I saw on Jalopnik that they have reproduced the entire shell
Old 09-29-2016, 04:23 AM
Raven 666
Raven 666's Avatar
Locked in always love your work 9M .................
Old 09-29-2016, 08:28 AM
NineMeister
Thanks for taking an interest guys.
The panels are all genuine Porsche. As far as I know, Dansk do not (yet) manufacture a complete bodyshell. The photos from the recent (Automechanica?) show demonstrate the panels they make in a contrasting colour to the 911 shell underneath.
Old 09-29-2016, 08:34 AM
NineMeister
This build was all about the restoration to factory standards of the rotten SC donor so at no time did we or the owner consider further enhancements to further stiffen the shell. That said, you are on the nail that if you are aiming high in the handling stakes shell stiffness should be at the top of the wish list.
Quick Reply: 9m11RS Part 1: Regeneration
