911 Forum 1964-1989
Muffler for SSIs
Old 08-27-2016, 10:34 PM
theiceman
Team Owner
theiceman's Avatar
Received 1,015 Likes on 722 Posts
Originally Posted by myflat6
Getting weight off the backend was a bonus as well.
I suggested this aproach for my wife too. She Is now my ex wife ...
Old 08-27-2016, 11:10 PM
psychoideas
psychoideas's Avatar
You're going to hell!
A friend of mine has just put SSIs and a Monty muffler on (77S). He really likes it. Personally I think it is a little loud, but it does sound good.
They're made down here in Australia and my friend picked it up from the factory. Well when I say factory I mean shed.........in the bush.
Rob (the friend) hang him to organise a pick up. He said I wont be home but I'll leave it outside so just put the money in the fuse box of the shed. It was just over $1000AU i think. That's about $750US
Old 08-28-2016, 12:03 AM
myflat6
myflat6's Avatar
Old 08-28-2016, 03:45 PM
chuck v
chuck v's Avatar
Love my M&K muffler with my SSI and Steve Wong chip.
Chuck
87 911
Old 09-08-2016, 06:41 PM
theiceman
Team Owner
theiceman's Avatar
Default they're here !!
YUM ...
Old 09-08-2016, 09:37 PM
myflat6
myflat6's Avatar
YUM ...
I agree. When I got mine I thought they were art worth hanging on the wall
Old 09-09-2016, 08:31 AM
09mageec
09mageec's Avatar
God, I need to get these. I bet everything sounds so good together !!
My heat exchangers are VERY rusted. Given I have not driven the car yet, just start it up now and then to keep the mice away. I would assume that a rusted pair would NOT be good to get too hot.
What sorts of problems that heat exchangers can cause, and why. Still a bit of a newbie..
Old 09-09-2016, 10:04 AM
theiceman
Team Owner
theiceman's Avatar
my originals were completely rusted out .. I then put on a very good pair for a later SC during my build, then these SSIs popped up after I was done of course.
Out of curiosity I ripped open my completely rusted out set. The actual exhaust pipes were really rock solid and could have gone another 30 years.
The effect you have with rusted out exchangers is as holes develop you just bleed out heat. or you have very localized heat at your feet because the engine fan that is trying to push the air to the cabin leaks out all the holes.
Incidentally my son and I were out during the long weekend in the Targa with no roof. I had not hooked up the replacement exchangers heat at the back end at all . but I did hook up the front end as I put the engine in with new flex hoses.
We pulled on the levers as it was getting cold expecting no heat at all and it came blasting through. I guess the venturi effect of the targa whipping along was drawing air through the system we had to turn it down after 5 minutes as we were roasting.
Old 09-09-2016, 11:25 AM
09mageec
09mageec's Avatar
I didn't even think of this! Could be the case with mine as well. Even still, I really should get a new set..
Old 03-03-2018, 05:36 AM
psychoideas
Ice,
Old thread I know but where did you get the 964 grind? Did you buy a set or did they modify your cams?
Old 03-03-2018, 08:59 AM
theiceman
Team Owner
theiceman's Avatar
Originally Posted by psychoideas
Ice,
Had mine reground locally to a 964 grind. There is a place in california that does it but it was cost prohibitive with shipping and duties
I think they were called web cams
Old 03-03-2018, 11:25 AM
buddalun
buddalun's Avatar
Ice,
Did you go with the Dansk Sport muffler with your SSIs? TIA.
Old 03-03-2018, 11:39 PM
psychoideas
Was it expensive to have the regrind? Does it effect the CIS in any way?
Old 03-03-2018, 11:43 PM
theiceman
Team Owner
theiceman's Avatar
500 bucks cad for both. I thought it reasonable
I have not noticed and cis issues. I need to put the exhaust on to benefit from cams. I may get around to it this year
Old 03-11-2018, 04:28 AM
psychoideas
Sounds like an OK price.
I better do some more research as to the effect on the CIS. I intend to go Carbs eventually so It'd be nice to get the grind that works best with carbs but will work with CIS till the Carby install time.
Quick Reply: Muffler for SSIs
