BBS Rs from 928 onto 911 question..
Hi guys! I have an opportunity to acquire a set of BBS RS wheels that I was thinking for track use given they give me more tire from what I have already. Originally mounted on a 928.
The sizes are:
16x8 ET 36 fronts
16x9 ET 62 rears
My question is, will these fit into an SC body?
Given my limited understanding of offsets, I am thinking It may be possible if I use spacers so they are not so close to the oil lines (rear) and the inner wheel wall (fronts)?
Any help would be greatly appreciated!
thanks
The sizes are:
16x8 ET 36 fronts
16x9 ET 62 rears
thanks
per the below Link, seems that I would be OK by adding 36mm spacers in the front, and 22mm in the rear...
http://forums.pelicanparts.com/porsc...he-911-sc.html
That 9" et14 [effective] should fit/tuck in nicely.
In any case, let us know how things turn out.
