911 Forum 1964-1989
Help with failed SMOG - high CO on low speed
Old 07-23-2016, 07:00 PM
Spyerx
Spyerx's Avatar
Received 1,729 Likes on 1,057 Posts
Default Help with failed SMOG - high CO on low speed
Any pointers? Car has passed every year w/o issue. stock cat, chip, etc. Motor is stock, plugs new, wires new, cap rotor new, seems to run OK...
ideas before i bring to my tech?
Last time almost all the measures are very very close except low CO, which time was .38
Old 07-23-2016, 08:44 PM
Techno Duck
Techno Duck's Avatar
High CO along with the higher than normal HC indicates running rich, what is the age of the O2 sensor? Also was the car fully warmed up prior to doing the test? The DME may still have been commanding a rich mixture if not up to temp.
Old 07-23-2016, 10:24 PM
Spyerx
Spyerx's Avatar
Car was very hot did freeway run and went right to smog place.
O2 sensor not sure age. Anything else cause this situation?
Does this ecu have any memory that needs to be cleared?
I have a Steve Wong chip, will this run leaner?
Old 07-23-2016, 10:25 PM
Lahainabry
Lahainabry's Avatar
I am not an expert on this but had the similar issue with an older 450SL. Mine was the 02 sensor.
However, it being bad ruined the catalytic converter. I had to do 2 sensors and the converter. Passes easy now.
Old 07-23-2016, 11:19 PM
Spyerx
Spyerx's Avatar
my hc are low so hope cat is good
Old 07-24-2016, 01:08 AM
esc911
esc911's Avatar
I've read on a few threads on pelican about the pin 10 (brown) wire needing to be connected for smog with the SW chip. Not sure if it applies to CO or NO.
Old 07-24-2016, 12:38 PM
Spyerx
Spyerx's Avatar
I have stock chip in the car and the pin 10'is unplugged (as delivered for Cali)
Old 07-24-2016, 05:17 PM
oldskewel
oldskewel's Avatar
Your HC are low enough to pass, but not as low as they could or should be.
For reference, here is my last smog at the 15 mph test (for my '85, so the specs are a little different):
mileage 133858
speed 15 mph
RPM 1494
CO2 14.5
O2 0.3
HC(PPM) MAX 97
HC(PPM) AVE 33
HC(PPM) MEAS 15
CO(%) MAX 0.59
CO(%) AVE 0.22
CO(%) MEAS 0.07
NO(PPM) MAX 804
NO(PPM) AVE 373
NO(PPM) MEAS 351
Your 91 HC is almost at the 97 max for my '85.
If it were me, I'd replace the O2 sensor, just in case it helps.
Old 07-24-2016, 06:32 PM
Spyerx
Spyerx's Avatar
Got a hand from an awesome local Pelican member, we hooked up an AFR meter and found it running really rich. So, swapped in a spare meter and bingo, perfect afr, better idle, more power, less stinky exhaust. I'm swapping the O2 sensor now and will make another smog attempt after running the car a bit to get it nice and hot. In meantime will drill out the adjuster screw on my meter so we can get it adjusted properly.
Fingers crossed!!!
Old 07-24-2016, 11:42 PM
C4inLA
C4inLA's Avatar
Spyerx,
Could you explain your last references to meters and drilling out ??? Hooked up a meter, swapped a meter? Sorry. Trying to education myself on A/F mixture in our cars, etc...
Thx..
BtW, sent your friend a note weeks ago and didn't hear back... I suspect, case of another one man show in demand. All good, I doubt he has time to be picking apart gearboxes...
Old 07-25-2016, 12:24 AM
Spyerx
Spyerx's Avatar
This thread I posted on pelican has more details
http://forums.pelicanparts.com/porsc...est-ideas.html
Old 07-25-2016, 01:46 AM
C4inLA
C4inLA's Avatar
Thanks, all caught up .... Community came through for you, awesome....
Old 07-25-2016, 02:18 AM
Spyerx
Spyerx's Avatar
Yeah let's see if it passes tomorrow. I'm optimistic!
Old 07-25-2016, 08:57 PM
Spyerx
Spyerx's Avatar
And we have victory! See the pelican thread for more details, but essentially adjusting the AFR while under idle fixed it along with a new O2 sensor. Car was running super rich.
Old 07-25-2016, 09:01 PM
Techno Duck
Always a relief to get that out of the way. I have to retest before March of next year, maybe earlier if i decide to sell. The car runs great but always makes me nervous!
Quick Reply: Help with failed SMOG - high CO on low speed
