Brake pad bolt socket
Hi there,
I have a panamera and I can't seem to find a socket to remove the bolt holding the pads to the caliper. Those of you that do your own brake work, where did you get the socket? I assume the 911 has similar Brembos as my Panamera has and previous Cayman had. Examining the bolt it appears to be a 10 point castellated head of about 10 mm.
Thanks for any leads, Dicky
Team Owner
i'm not sure there is much of a DIY section for the Panamera either..
they might be able to help you here though
https://rennlist.com/forums/panamera-167/
