SSI versus plain steel heat exchangers
I'm restoring a '69 911T, and am interested in folks' thoughts about replacing the rusted out heat exchangers with SSI versus regular steel. I can get the SSI for ~$1500 per set, versus ~$1000 for the steel. The restored T won't be a DD, and rust is not a big problem here in CO. On the one hand, it seems to me I won't get any real benefit from the SSI and there are better places in the resto to spend $500 (such as on minty arm rests), whereas on the other hand $500 isn't that much in the grand scheme of things. Thoughts?
Thanks in advance,
RIch
Thanks in advance,
RIch
Go for the SSI Heat Exchangers
Type 2
RL Technical Advisor
Thanks in advance,
RIch
Thanks in advance,
RIch
The main reason to ditch your original heat exchangers is for safety reasons. Those OEM ones likely have pin holes in the tubes which puts carbon monoxide in the cabin when the lever is pulled up.
This is a VERY serious issue which can easily kill you and why we usually replace those old ones with SSI's.
