911 Forum 1964-1989
PCM1 CD changer plug - where is the anti-shock control?
Old 05-25-2016, 05:39 AM
N111los
N111los's Avatar
Default PCM1 CD changer plug - where is the anti-shock control?
Hi everyone, I have just switched the input plug for my cd changer and added a 3.5mm jack input to the CD changer socket on the PCM1 on my 2002 996 Carrera 2 using one of these cables from eBay.
http://www.ebay.co.uk/itm/Blaupunkt-Aux-IN-Input-I...
Works a treat and I can now plug into my phone and listen to music from that on the CD channel and it only cost £5. I am planning to get a cheap bluetooth receiver from amazon and wire this in to get bluetooth stereo connection. I already did this on my landrover and the total cost was £15.
The only issue is when I go over bumps the audio momentarily drops out which i think is down to the anti-shock from the cd changer which is still running telling the head unit to mute.
Does anyone know if my assumption on the audio dropout is correct and if so is it possible to disable this anti-shock functionality? Are any of the wires in the other CD changer input plugs (yellow and green) responsible for this?
I tried unplugging the green plug, but the PCM then says no cd changer and I don't get any audio.
The CD changer input (plug c) consists of three coloured connectors - blue which is the one I changed, yellow and green.
The pins are as below:
Plug C
1 - Lineout, rear left
2 - Line out, rear right
3 - AF ground
4 - Line out, front left
5 - Line out, front right
6 - Terminal 30 for amplifier
7 - Control lead for CD changer
8 - Terminal 30 for CD changer
9 - Free
10 - Data lead
11 - Clock lead
12 - Reset lead
13 - Free
14 - Free
15 - Free
16 - Free
17 - Free
18 - CD AF, ground
19 - CD AF, left
20 - CD AF. right
Note Plug C consists of 3 parts.
Pins 1 to 6: yellow housing.
Pins 7 to 2: green housing.
Pins 13 to 20 : blue housing.
Pins 1 to 6 are the loudspeaker outputs to the amplifier. They are assigned only if an amplifier is installed.
Pins 7 to 12 are the control leads for the CD changer.
Pins 18 to 20 are the loudspeaker outputs of the CD changer.
Pins 7 to 20 are assigned only if a CD changer is installed.
Old 05-26-2016, 04:36 PM
theiceman
Team Owner
theiceman's Avatar
Received 1,026 Likes on 730 Posts
huh ?
I think you are in the wrong forum , this forum is for 911s ( -89) I think you want the 996 forum in the water cooled section.
Quick Reply: PCM1 CD changer plug - where is the anti-shock control?
