Stalling at stops and startup
Something inside the ecu needed to be soldered and that is what fixed the problem. That's why it needed to be sent to a place like ecu doctors.
If everything else on your car checks out and the problem is still there. Then you would need to install a known good ecu and see if that fixes the problem, if it does then you know the problem is in the ecu.
Acting up again. switching out ICV this am, let's see.
So between last night and this am, she stalled out multiple times at a stop and idle hunted on startup.
I brought her in and mechanic swapped out my recently cleaned ICV for a a good used ICV they had lying around. Out of first handful of stops she almost stalled twice, but since then and 130 miles later, seems to be spot on. Probably had 15 stops in a row that were perfect, and a couple perfect startups. Not sure why she almost stalled twice in beginning though. He said if this doesn't fix issue, then they will swap a dme.
Thoughts on why initially, she almost stalled twice w/ the swapped ICV??
May have been sticking due to lack of use. Once warmed up and moving it loosened up. Who knows?
If the problem persists, I'd check the condition of the reference sensors on the flywheel.
Hopefully that's it, if not mechanic said he will swap a DME in. I'll mention flywheel
Took her on a nice thanksgiving morning run. So nice out in NY, that top was off and people were surfing! Still intermittently stalling, so I would say it's narrowed down to DME now, I'm which I will test a replacement one next week. Happy Thanksgiving!
By chance, anybody have a DME lying around in the Hamptons??
Anybody have a video of how to change a DME?
Even a pic of it's location will do, i can then figure out the removal myself.
Team Owner
the cht is the cylinder head temp sensor. it is the top connector of the connectors on the left... see if it has one wire going to the sensor or two
