Help needed to listen to a partential purchase
#31
Should be just pence changes to address. Can you post pictures? It makes it so much easier for my pee wee brain to be sure we are talking the same thing.
Congrats on your buy. I bought a 74 with slantnose this summer but decided to go back to stocking IB set up. Still haven't driven it.
#32
Hi, it's looking like the rear is just a lense change, at the front the us model slant nose has two fogs below the bumper and then 4 lights in the bumper, all are orange lenses, where as on the European version it's just the fogs and pair of lights, the rubber insert in the bumper found on both versions, replaces the pair of park lights on the European version. I'm going to call a parts shop tomorrow might shed some light..I did add a pic using the paperclip, not sure if it worked?
#33
I'll be making a list of jobs to do her, top of the agenda get the lights sorted so it passes an mot then I can send of for a reg document and then I can drive her on the road, a couple of things...Targa roof doesn't fit properly, looks like a simple adjustment, it sounds like i'm driving with the window open at the moment, clutch is fairly heavy, I had 928's over a 15 year period the clutch with a helper spring was still fairly heavy, is there a helper spring on the 911? Oil gage, two of these one on the left of the steering wheel was dropping very low into the red square on my journey back from the docks when I was on the motorway, the other gauge on the right stayed high in the numbers on the motorway...
#34
Team Owner
there is a vendor on here selling repro lenses, they look quite nice , do a search.
Make sure to search "Porsche 101" it will get you started.
#35
Hey guys, lenses all changed and it's passed its m.o.t now!! So I have sent the paperwork off to get its registered in the uk. While that's happening i've put it in my new garage, i've just built the garage and at 40 I finally have a garage to work on my car! Lots to do on car but I want to keep it mobile so I can use it as soon as the registration comes back. First job is the Targa roof that doesn't fit properly...
#36
