'84 911 AC Schematics?
911 build date 9/83 early 3.2. AC compressor getting power with the key in the on position along with pin 86 on the relay, engine not running. Engine running pin 86 and compressor no voltage. When you turn the key off (engine running) just before the engine stops you can see the AC compressor move, .8 volts at pin 86. Does anyone have AC schematics for a '84 911? What I can find on Pelican stops at 1982. Thank you.
