911 Forum 1964-1989
7" and 8" x 15 tire choices..
Old 07-01-2015, 03:41 PM
mpiffaretti
mpiffaretti's Avatar
Default 7" and 8" x 15 tire choices..
I have a 76 911s I just acquired that came with original 7 and 8 x15 Fuchs. It has flared rear fenders (rolled), so basically the same look as an SC space wise.
It came with Toyo RA1 tires all around, and they are all the same size of 225-50-15, which makes the front tires bulge on the sides a bit.
My question is, should I change the fronts to 205's to match the 7" rim? or do I leave the 225's?
My rear wheels have spacers and are basically maxed out on fender clearance, so the car is definitely staggered wheel wise. In your opinion, leave as is? or can this be optimized?
The car is a weekend car used for spirited driving and perhaps an occasional autoX and track duty (maybe twice/year).
thanks for the input.
Old 07-01-2015, 04:20 PM
Bill Verburg
Bill Verburg's Avatar
My '76 Carrera 3.0 came oe w/ 7 & 8 x15 205/50 & 225/50 tires, that worked great for me, you could also use a 205/55 front or 225/45 rear
usually w/ SC/Carrrera rear flares you wouldn't need a spacer w/ 8 ET10.6 Fuchs
Old 07-01-2015, 05:23 PM
mpiffaretti
Thanks for the input Bill.
Then I'll probably order 205/50's for the front and keep the old 225's as rear spares.
Old 07-01-2015, 06:17 PM
mpiffaretti
I just realized my tires are 10 years old per the code on the sidewall, so Im going to replace all 4 tires with fresh rubber.
Seems that on the 205/50 x15 and 225/50 x15 the options are very narrow. So out of the below options, what would you pick?
Yokohama ADVAN A048
Toyo Proxes R888 or
Toyo Proxes RA1
Old 07-01-2015, 06:58 PM
Bill Verburg
Yokohama ADVAN A048
Toyo Proxes R888 or
Toyo Proxes RA1
RA1
Old 07-01-2015, 11:04 PM
Bola964
Bola964's Avatar
Bill,
How about the Avons CR6ZZ? 215 front and 225 back seems to be the best options.
Thanks.
Old 07-02-2015, 09:49 AM
Bill Verburg
Among other things the Avon tires that might fit are awfully tall, this negates the benes of using a 15" wheel
You might as well use a 16, 17 or even 18 and get the benefit of modern construction and multiple choices
Old 07-02-2015, 04:49 PM
JCP911S
JCP911S's Avatar
OP... the 911 is "rear-tire" challenged.... I'd like the most rear tire I can get, but IMHO, a narrower front tire works just fine....
First, unless you dial in ridiculous camber, you can't get a 225 front tire flat on the road anyway, and wide tires tend to "tramline" and give darty handling.
For a street 911 a 205 is a perfect front tire option.
Old 07-03-2015, 12:12 AM
Bola964
Bola964's Avatar
Thank guys.
I'm very inclined to go with the Michelins TB-15.
Front: 15/60-15 (170/65VR15)
Rear: 18/60-15 (215/55VR15)
A bit narrow in the front, but a compromise to get the tires I want.
Thanks.
R.
Old 07-03-2015, 12:16 AM
Bola964
Bola964's Avatar
I was told this car is running the 18/60-15 Michelin TB15 215/55VR15 in the front and rear.
These are exactly the same wheels I got! 7x15 and 8x15.
Old 07-03-2015, 10:39 AM
mpiffaretti
I Pulled the trigger and went with the Toyos RA1's, while researching RL seems that most people prefer them over the R888.
205's in the front and 225's in the rear it is!
Thanks to all for their input.
Old 07-03-2015, 07:14 PM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
That's what I have on my '74 Carrera and I just love 'em.
Old 08-15-2015, 06:28 PM
mpiffaretti
Anybody knows what PSI should I use on the above tires for track use? Im doing a DE tomorrow at Homestead and could definetely use some input.
Quick Reply: 7" and 8" x 15 tire choices..
