Rebuilt 3.2 Engine from 85 911
Former Vendor
Just rebuilt 1985 3.2 L engine with 0 hours.
3.2 liter engine. Crank: inspected and micropolished. New main bearings. Rods inspected and sized. New rod bolts and nuts. New rod bearings. New piston rings. Cylinders inspected for size. Oil pump inspected for wear. Cylinder heads received valve guide and seat service and cylinder surface recut. All new seals and gaskets. Stock cams. New rocker shafts and motosports seals. New chain guides. New oil pressure sensor.
If I think of anything else I will forward.
contact Scott
baymedpro@aol.com
contact Scott
baymedpro@aol.com
