Engine drop restart procedure 89 3.2
Hi guys, It's been a journey - especially for this novice - but after dropping engine and trans to replace clutch and a bunch of other things "while I was in there", I am very near ready to try to fire her up. I pulled fuse 6 which reads fuel pump, but wanted to know based on your experience what other precautions I might take while I get the oil pressure up. I know I read a post on this in the past but I can't find it. Thanks
Team Owner
With no fuel pump that's all you need. Remember. Do not over crank. I'd go 20 seconds max a few times letting starter cool between. Then pop in the fuse and go
No rides yet. Had issues with clutch pedal not returning. Blead out hydraulics another time and had a good look at the cluster and the adjustment cam. Clutch master cylinder making ugly noises but no leaking. Decided to replace it, so.... Waiting for a part (again). Hopefully get her on the road in another week or so.
