911sc rear shocks
911sc rear shocks
Hi everyone. Running 23mm rear spacer on a stock 1983 SC. I like the way the car looks and sits but the tyres rub slightly over speed bumps on the outer fender edges. Needs some ideas on options I have to solve the problem. Thinking of rolling the fender edges slightly of replacing the rear shocks? Sachs shocks any good?
Smaller spacer have a clearance issue with the bolts on the back of the alloys. Will try the negative camber as the first option. Any recommendations on rear shocks? Sachs any good as a replacement for the rear?
I would not stoop to Sachs shocks. Bilstein HD's if it's a street car and Sports if it is used for fun. My Rear Bilstein Sports go back to Bilstein on Tuesday for modern valving.
