Front Wheel Fitment on 911SC
Hello,
I was wondering if this is a good reference for wheel fitments?
http://instant-g.com/Products/Wheels/WheelFit.htm
I see that 9x17 et53 (-19mm for spacers so final et34) and 245/40/17 tires is considered a 'Medium' fit, is this true? Any experiences with similar setups.
Thanks in advance for any help.
Before you spend megabucks on new wheels, what are your plans for the car?
If it is primarily a street car, I'd stick with the factory Fuchs. Big front wheels don't really help performance on these cars, and can cause tram-lining, scrubbing, and higher steering effort.
For the same money as new wheels, lowering the car and doing a mild performance alignment will give you a really nice look, and improve handling.
It's your car... do what you want, but in the real world, tire construction and compound make a much larger impact on actual handling performance than size.
Thanks for the input, you raise some valid points.
Thanks....
Coupled with a 225/45/17 tires, based on what I've been reading.
I think that et16 with some camber adjustments and the above tire may still be too tight of a fit.
I have Euromeister 17x7 ET 23.3 on the front of my 88 Carrera and the fit is very snug. I will be dialing in more negative camber and rolling the tops of the fender lips. The 225/45-17 RS-3 tire was catching the fender lip on the right side. A lot depends on the actual dimensions of the tire. I think that 215 would be a better fit.
For autocross I use 15x7 ET 23.3 fronts with 225/45-15 BFG Rivals. There is a ton of room for those as the O.D. is 23" compared to 25" for the 245/45-17.
Cheers
