3.0 sc clutch install question
I have a pronounced vibration coming from the motor/drivetrain. I recently finished a clutch job using an aluminum pressure plate. My question is, is it possible to install the pressure plate out of alignment somehow? When I put it in, it seemed like it would only align (the bolts) one way. I hate the thought of pulling everything again....
Team Owner
I havent done my clutch yet, starting in a few weeks , but have read about using alignment tool . Other than that i cant help much sorry. Did you replace a rubber centred clutch with a spring centred clutch or was that someone else ?
I did with a spring centered clutch. Found out it is not possible to be installed incorrectly. I am now thinking it might still be an ignition issue. Changing the cap and rotor helped smooth her out, but the underlying vibration is still there. Has to be some sort of misfire. Ugh.
