Need transmission help (915) tranny
Hi everyone, and thank you in advance
Picked up an 82 911 with a "rebuilt" 915 tranny
unloaded it off the truck
while doing that noticed a clear greasy fluid underneeth dripping out
and dripping while driving. I was think hydrolic fluid- its deff not oil.
So 1 drove about 1 block car will not go in gear, I press the clutch put in gear but its not grabbing, i also hear a slight chatter after doing this and putting the car in neutral and not pressing the clutch then it goes away
main thing is the leak, then it not grabbing, theres no grinding.
Any ideas?
Any ideas?
Your clutch isn't hydraulic it's mechanical. The only fluid not motor oil in the rear is tranny fluid.
You need to check that out as I don't see many leaking tranny issues posted.
It could be a few things...could be the clutch fork gave way so the clutch is not being properly/fully engaged. Or it could be totally out of adjustment with a stretched cable.
Do you have a Service Manual so you can kind of bone up on the system?
Issue update.
I finally got my fat *** under the car, the leak is the right front brakeline/ bleeder screw which got caught- dot3 clearish fluid leak
issue wasent tranny/clutch- but a broken CV joint on the limited slip. no wonder it wasnt moving.
hope this can or may help others
