1976 911 2.7 engine flywheel to crankshaft bolts
flywheel bolt size 911 2.7engine
What is the flywheel to crankshaft bolt hole size for a 1976 911 2.7 engine?
The 6 bolts seem to measure 12mm x 1.25 but the only technical manual I have says they should be 12mm x 1.50. I want to clean out the thread holes with a tap since they seem to have loctite residue in them.
Thanks,
Mark
Thanks,
Mark
