911 Forum 1964-1989
1970 911 E suspension
Old 09-16-2014, 10:57 PM
Baxter2012
Baxter2012's Avatar
Default 1970 911 E suspension
This question is two fold
I have this car and it has Macpherson struts on the front w/alloy calipers. I know replace with Konis and move on but i am a little true to the original. If need be can these be rebuilt with seals etc. by someone you know?
Rear suspension on a 1971 T does anyone know what the angle should be on the spring plate when it is hanging free on the torsion bar to get the correct ride height in the rear?
Thanks in advance for any help.
Old 09-17-2014, 11:21 AM
ron mcatee
ron mcatee's Avatar
Are the struts Red(Koni"s), Black (Boge) or Green (Bilstein's)? Depends on what you want. Many like the Bilsteins since they can be re-valved. You can also find Bilstein and Koni inserts for the Boge struts.
The angle depends on where you want the ride height.
Old 09-17-2014, 11:04 PM
Baxter2012
Baxter2012's Avatar
Default Suspension
The front are the original hydropneumatic that I need inserts for sorry
Do you know the starting point for the rear?
Old 09-17-2014, 11:45 PM
ron mcatee
ron mcatee's Avatar
First, I would suggest removing the front Hydropneumatic struts and putting regular struts on it. What do you mean starting point for the rears?
Old 09-19-2014, 10:07 PM
Marine Blue
Marine Blue's Avatar
Make sure you keep the stock parts when you convert to regular struts.
Old 09-19-2014, 11:19 PM
Baxter2012
Baxter2012's Avatar
Default Rear supension
When the spring plate is hanging free on the torsion bar I am told it needs to be hanging at a certain angle what is that starting point, 25, 37 degrees at what angle?
Old 09-20-2014, 08:36 PM
Baxter2012
Baxter2012's Avatar
One last try
Anyone know what the angle should be on the spring plate when it is hanging free on the torsion bar before you hook up trailing arms, shock etc.
Quick Reply: 1970 911 E suspension
