Bendzall in my 91
Bendzall in my 91
After working on my Kawasaki H2 yesterday, I added a little Blenzall Gold Label in the tank before taking a ride. When I came back, I decided to add some to the tank in my 1988 911 Cab. The directions for a 4 cycle engine specifies a pint of Blendzall per 4 gallons of gas. So, we almost a full tank of gas in the 911, I added 3 pints. All I can say is WOW! After a few miles it was apparent that the Blendzall Gold Label gave the old 3.2 quite a boast in power. While not dyno verified, from my seat-of-the-pants, I felt a bigger boast in power than I did when I added the SW chip earlier this year. While Blendzall Gold Label is rather expensive to use, my Sunday mountain runs, I will be adding it again..try it and see what you think: www.blendzall.com
What about your O2 sensor and your Cat? I would even worry about build up on the exhaust ports. Motorcycle race engines get torn down between races ....or at least more often than car engines do.
My 911 has no cat. But, I have used Blendzall in numerous 4 cycle and 2 cycle motorcycles for the last 4 decades with no problem.
