911 Forum 1964-1989
911 SC Chain tensioners.
Old 08-25-2014, 02:29 PM
mpiffaretti
mpiffaretti's Avatar
Default 911 SC Chain tensioners.
Guys good afternoon, quick question, how can I tell if my SC has had the Carrera tensioner upgrade? if somebody can post a picture with the "before" and "After" it would be great. Lastly, if needed to be replaced, how much should the cost be for labor alone?
thanks!
Old 08-25-2014, 05:25 PM
obscene
obscene's Avatar
you'll see an oil line coming out of each of your tensioner covers if the carrera tensioners have been installed
Old 08-26-2014, 08:39 AM
psychoideas
psychoideas's Avatar
what he said!
Old 08-26-2014, 08:40 AM
psychoideas
Question
Old 08-26-2014, 10:13 AM
mpiffaretti
perfect, thank you. I just checked and I don't have that upgrade. Is it absolutely necessary in your opinion? I read some many contradicting posts in which some will swear by Mechanical tensioners, and some by their oil fed ones. Both sides claim both tensioners fail at some point. What's the definite answer?
Old 08-26-2014, 12:08 PM
obscene
obscene's Avatar
the oil fed tensioners are less likely to fail, but not 100% immune to failure. I don't have the link handy, but the safest bet is to use the oil fed tensioners with a piece of metal tube inserted in the base of the tensioner which prevents it from collapsing completely in the event of a failure.
Old 08-26-2014, 12:56 PM
mpiffaretti
I've seen those. I think they are called Collars made of aluminum that go around the Piston.
Old 08-27-2014, 10:42 AM
obscene
obscene's Avatar
the collars are only compatible with the non-oil fed tensioners. they are a much debated 'fix' that clamp to the piston and prevent it from collapsing. I think people worry that pieces could break off and cause futher damage.
the inserts I was referencing are better described here: http://911t.pca.org/tech_tips/limiti..._pressure_.htm
Old 09-01-2014, 07:19 PM
autobonrun
autobonrun's Avatar
Pressure fed tensioners are universally accepted as the optimum solution. I chose the less expensive option of adding the mechanical stops 30 years ago for about $60 in material. I think the pressure upgrade now is over $1000 parts and labor. Back then it was around $600. If I do have a tensioner failure or have to go in that area of the engine, I'll go back with mechanical tensioners and new collars. So far I'm at 213k miles and have not had to open engine. You'll have to decide which gives you peace of mind. My comfort level is fine with just the collars and mechanicals, but I understand those that go the extra step.
Here's good reading on the subject by Roland Kunz. It's a thirteen year old post but the details remain valid. One guy interrupted intelligent conversation but you can ignore that part.
http://www.early911sregistry.org/for...p/t-31886.html
Quick Reply: 911 SC Chain tensioners.
