Tiptronic in early 70s 911
I'm wanting to put a tipronic transmission in and early 70s model 911. Before you all crucify me, understand that I am paralyzed and have to drive with hand-controls (one hand gas/break the other to steer. I can't operate clutch) I am wanting to get a tip trans/engine from a 993 or 964 and have it fit into it. Does anyone know if it would fit? Does anyone have a ballpark on how much would it cost? My other option is to get a 964 and "retro" it to be like to car I wish I could get. I really love the old style and prefer the weight over the heavier 964.
Thanks,
Sean
(Tennessee USA)
Thanks,
Sean
(Tennessee USA)
I'm not sure a tiptronic would mount up to the old air cooled cars, good question.
The old sporto transmissions from the late 60's might work but you still have to shift gears in them. The shift lever has a microswitch that senses pressure and as soon as you place your hand on the gear lever to shift gears the switch disengages the clutch using vacuum. You shift gears, let off the handle and the clutch reengages. It shifts just as fast as a manual can be shifted. The other upside is that you can come to a stop without shifting into neutral, it has a torque converter in it. That transmission may mate up to the later cars up to 1998.
I'm selling my 69 pretty soon but while I have it I can take a video of how it works if interested. You might also be able to find a video online on how they work.
Happy to hear that your trying to achieve your goals despite some challenge ..the early cars long hoods to be specific could be pricey to say the least a solid non rusty decent roller
Could run ten or more thousand these days then the cost of a tip trans mounted to say a
964 3.6 another ten and someone to nstall an additional 7500 to ten so your at thirty
Before you get a test drive..
I would recommend finding a 964 with tip as you mentioned they are readily available
Get your controls installed and then go about backdating some to lighten it up if you choose
awesome project keep us posted...Bert
I have a good friend who owns a 74 Carrera with a Sporto and he is paralyzed and utilizes hand controls. He is an adept driver and even does quite a few track events with the car. He has driven this setup for over 20 years and it is really cool to see how well he has made the car work for him. He even had his wheelchair designed to fold up and fit behind the drivers seat, impressive. If it would be useful to talk to him PM me and I could put you in contact.
On the Tiptronic front, i certainly understand since i own both early cars and 964's. 964's are amazing but feel different from an early car. I think even with that you would still find it easier to backdate a 964 TIP than work the other way.
RL Technical Advisor
Installing the Tip in a pre-'89 car is a daunting task since you would need the G50 torsion bar tube, and the complete ABS system to provide wheel speed info to the transmission.
In short, the whole powertrain plus harnesses and the complete ABS package.
Its absurdly expensive to do this.
I'd recommend buying a Tip car and customizing it to suit your tastes as this is FAR cheaper to do.
Ok, so I have a 94 C2 as soon as it passes the ppi and I go pick it up. I will just be back dating/modifying it to perform a little better when I get the chance.
I have tried to contact a dencent number of shops I have found on here and haven't had luck with getting a response. I live in eastern Tennessee. Do any of you have a shop recommended that is somewhat in my region? I am going for a cross between a Singer and a 73 RS for looks and would like to lighten up wherever I can.
Thanks,
Sean
Thanks,
Sean
Thanks,
Sean
Thanks,
Sean
Sorry I can't help with a good shop but mine are a bit far from you.
Please keep us updated with your project.
I'd love to do something like the PS Retro Touring R <http://www.psautoart.com/ps-cars/Retro-Touring-R/474> or even something like the Singer. I guess at this point my biggest challenge is getting the right shop/person to do it. I'm not willing to ship my car over to the UK and the 300k+ price tag for the singer is a bit too much for my budget.
