911 Forum 1964-1989
I know where some of the oil is going
Old 01-10-2013, 09:40 PM
Reiver
Reiver's Avatar
Default I know where some of the oil is going
The lower (turbo) valve covers were slightly warped so planed them on some glass for a tighter seal. Would explain some oil loss but no drips on the floor (maybe one..two max) but often nothing. More seepage and a dirty block than an identifiable leak source.
All of the head studs still in place and retorqued slightly under spec for safety sake bless their little non breaking hearts.
Old 01-10-2013, 11:32 PM
Amber Gramps
Amber Gramps's Avatar
What am I missing? Are you loosing/using more oil than usual?
Old 01-11-2013, 09:00 AM
Wachuko
Professor of Pending Projects
Wachuko's Avatar
Cool
Originally Posted by Reiver
...All of the head studs still in place and retorqued slightly under spec for safety sake bless their little non breaking hearts.
I can imagine the stress of checking that
Old 01-11-2013, 10:02 AM
theiceman
Team Owner
theiceman's Avatar
Received 1,021 Likes on 726 Posts
Thats one area i belive that if it aint broke dont fix it .. When i do my valve adjustnment i just make sure there are no broken studs .. and leave it at that .. i aint touching those things ..
Old 01-11-2013, 11:18 AM
Reiver
Reiver's Avatar
Yeah I know, so I torqued them to check going 8 lbs under spec...no more oil usage than normal, still a tad over 600 m per qt (620-650) but the warped covers allowed seepage.
Old 01-11-2013, 02:36 PM
dshepp806
dshepp806's Avatar
I ain't touchin' ;'em either!!!!!!!!!! Damned right Ice (hehe).
Doyle
Old 01-11-2013, 02:58 PM
Reiver
Reiver's Avatar
Actually I asked Jack at Stuttgart SW how they check them and did that....he said if they are in basically ok to good condition they'll be fine. I wanted to know so took the chance....worked out thankfully.
Old 01-11-2013, 03:01 PM
Peter Zimmermann
Peter Zimmermann's Avatar
600 miles/quart. Not really bad, yet. If the valve train is quiet, and it doesn't smoke during decel, leave it alone.
SC/Carrera head studs: Lookie, but NO torqie...
Old 01-11-2013, 03:05 PM
dshepp806
dshepp806's Avatar
yeap,..no "torqie".......!
Doyle
Old 01-11-2013, 03:32 PM
Reiver
Reiver's Avatar
It smokes a tad during decel but only if you run it up to 4 or 5 grand 2nd/3rd and totally drop off the go pedal. The valves are not sloppy in the guides so I'm guessing some slightly worn oil scrapers....leak down is still good tho at 3-6 psi per pot.
Not bad for 227k.
Too late on no torqie tho...but survived. I'm not anxious for another try believe me.
Old 01-11-2013, 09:34 PM
rusnak
I haddah Google dat
rusnak's Avatar
I'm with the lookie, no torquie crowd here.
Lest you enjoy a butt-puckering, millimeter by millimeter fingertips only exercise.
I can think of better places to look for oil loss, such as the oil return tubes or topside usual suspects ("triangle of death"). If your clutch is slipping and you have oil from the bottom of the tranny bellhousing, then the crankshaft seal is another one. Only nasty is the #8 bearing seal. That one is no fun.
Old 01-11-2013, 10:17 PM
Reiver
Reiver's Avatar
Wasn't looking for it actually....valve adjustment and noted warped valve covers. Now not even one drip of oil after a 200 mile round trip today.
Old 01-12-2013, 10:49 AM
Ed Hughes
Ed Hughes's Avatar
Let me see....he does what for a living?
And that, from a gentleman who made a living for many years working on these babies.
Old 01-12-2013, 09:08 PM
Reiver
Reiver's Avatar
Ed, normally I'd agree with you but Jack is one of the most honest guys I've ever dealt with in any business. He's the guy that checked my car for possible rebuild and told me to come back in 5 years for a recheck...also consider the guy a friend. I trust his Porsche knowledge. He's been doing nothing but Porsche's for over 35 years as a wrench and now as the owner.
There are a few guys on this site that know him and I'd guess they'd say the same.
Old 01-13-2013, 09:47 AM
theiceman
Team Owner
theiceman's Avatar
Still reiver, you have ***** of steel. Wether you realize it or not
Quick Reply: I know where some of the oil is going
