Why not... another project...
#226
Professor of Pending Projects
I sure hope so... after the work I have been doing on the 912, there is a lot that I want to do to this project... so a few details will go back to the drawing board.
I have the dash and top door, rear side window trim ready to take to the upholstery shop... but now I am not sure if I was to do the two tone or just do it all black... need to decide in the next few days as the dash must be installed before Alejandro can install the windshield...
#235
I have to say... very difficult color to photograph... and could not get it outside since it was raining... Alejandro started the wet sanding...
Leather to use on the dash and top of doors and windows... two tone interior... the bottom panels will be black...
#240
Thank you. Yes, it is finally moving again!
Had to order the Left side assembly for the 993 door handles... could not find one used, gulp$$... had to reorder the clear front turn signal lenses because those dropped from the shelve and broke And also had to order new housings for those as mine where also in unrecoverable condition...came up empty searching for used ones...
Now to spend time recovering the dash in the leather I just got...
