911 Forum 1964-1989
Heuer Dash Clock
Old 01-11-2014, 06:46 AM
  #31
jorijori
jorijori's Avatar
Eatbreathedrive, who did your gauges? My 964 gauges face plastic skin is peeling on the warning lights probably due to heat from the light.
Old 01-11-2014, 07:34 AM
  #32
deactivateduser66
deactivateduser66's Avatar
I only put aluminium rings around the gauges but the face plates, I haven't changed them yet, the car is an original 26K miles. The alu. rings is a nice touch, definitely freshens up the car.
Sent from my iPhone using Rennlist
Old 01-11-2014, 10:15 AM
  #33
jorijori
jorijori's Avatar
Thanks, from your picture your gauges faces appear to be grayish color. Nice car...
Old 01-11-2014, 11:23 AM
  #34
oprevot
oprevot's Avatar
Singer had the Heuer clock listed for $2,500. Click on the link below.
http://www.motor-talk.de/forum/aktio...hmentId=679361
Old 01-11-2014, 05:28 PM
  #35
racerbvd
racerbvd's Avatar
A buddy redoing his 86, back dating to 74 Carrera He has some really sweet Heuer watches, so when I showed him this, he had to have one..
Old 01-11-2014, 10:08 PM
  #36
jorijori
jorijori's Avatar
Nice dash Racebvd, did you get it from Marek too?
Old 02-16-2015, 05:28 AM
  #37
Apaches
Apaches's Avatar
Default RS RSR ST Heuer Style / Singer Inspired Clock Face available
Finally picked up my VDO dashclock face replacement dial at Littlecustomthings
Special Thanks to Chris and his great work.
This face will fit and replace the original clock face, of
911 641 701 29 and 911 641 701 00 fitted on cars from 1965-1989.
Its not the Singer stuff but it works for me.
Subdials don't work but its also the case on the Singer one.
Contact him directly in case you want one.
Just passing on the message
A.
Old 02-16-2015, 10:29 AM
  #38
Ed Hughes
Ed Hughes's Avatar
Seems like a poser thing to me.
I'd also not advertise, if I were your supplier. I'd think a cease and desist letter isn't too far away, should somebody get wind of this.
Old 04-06-2015, 11:01 PM
  #39
Ferd the Bird
Ferd the Bird's Avatar
If I'm not mistaken, the Singer folks were "encouraged" to stop making the Heuer clocks early on......
Old 04-07-2015, 06:54 AM
  #40
Wachuko
Professor of Pending Projects
Wachuko's Avatar
I had the Heuer face that I was going to use on my RS project until Imsaw that new one. Well... I moved the clock with the Heuer face to the RSR...
Photo installed in the RS:
Now installed in the RSR:
Got the new face and installed it on the other clock. This is the clock that will go in this RS project instead... Yes, it is for looks, but I like it!
Old 04-29-2015, 12:07 PM
  #41
Apaches
Apaches's Avatar
Default Porsche 911 VDO Clock Dial Heuer Update
Because making the perfect dial took quite some effort and a lot of trial and error….
and I can only fit 1 clock to my car…
Chris from Littlecustomthings decided to sell the designs that didn’t make it.
He has at least 1 of each. They are all made of metal. To my opinion… all designs are individually little pieces of art.
He told me he would still fit the 3 small hands to the ones with subdials.
Feel free to contact him directly at Littlecustomthings@gmail.com.
I am just passing on the message.
Old 04-29-2015, 02:01 PM
  #42
Rico
Rico's Avatar
Jamie,
How do you remove the black metal ring holding the glass in?
I took a look at mine and it seems to be crimped on by the VDO factory.
Old 04-29-2015, 05:12 PM
  #43
Wachuko
Wachuko's Avatar
Originally Posted by Rico
Jamie,
You carefully lift it with a small screwdriver or thin rod...bend it out until you can remove it. Easy does it...
Old 05-04-2015, 06:38 AM
  #44
Apaches
Apaches's Avatar
Default 911 VDO Kienzle Clock Updated Dial Face
Dials with finished hands installed
Old 05-22-2015, 06:00 PM
  #45
Rico
Rico's Avatar
Thanks for the info Jamie.
Quick Reply: Heuer Dash Clock
