911 Forum 1964-1989
Where do you buy Swepco 201?
Old 04-29-2003, 08:56 AM
HJV11
HJV11's Avatar
Question Where do you buy Swepco 201?
I am getting ready to change my oil, set my valves and plugs. I would like to change the tranny fluid also since I cannot verify the last time it was done (new owner). So where do you get Swepco 201?
Old 04-29-2003, 09:30 AM
Bill Gregory
Technical Specialist
Lifetime Member
Bill Gregory's Avatar
Post
Best price I've seen is from Foreign Intrigue, who has it on sale each Jan and Feb. You might contact them to see what their current price is. (www.foreignintrigue.com). No connection, just a satisfied customer...
Old 04-30-2003, 02:36 AM
garyo4
7th Gear
garyo4's Avatar
Post
Try Pelican Parts!
Gary.
Old 05-01-2003, 06:09 PM
Chuck Harmon
Chuck Harmon's Avatar
Post
I have to add here that I just put Swepco 212 in my 83SC.I had been running 201 and decided to try the 212 to see if I could tell a difference. WOW !! Without question this made a difference. I got the 212 from Pelicanparts.
Old 05-02-2003, 07:50 AM
HJV11
HJV11's Avatar
Post
Chuck, what is the difference between 201 and 212? Is it just a weight difference or was are there different additives?
Old 05-02-2003, 10:34 AM
Chuck Harmon
Post
212 is a 80-140 weight.
It has the same additives as 201 just a multi-viscosity rather than a straight 90 weight like 201
Old 05-02-2003, 10:55 AM
jet911
jet911's Avatar
Post
Chuck,
IYO, would 212 be OK in a 915 tranny that had a rebuild about 1,000 miles ago? I'm getting ready to drain her out and replace. I was going to go with 201 (the wrench used Castrol, after he drained my 201 out when it blew a seal), however I have not ordered yet, and if 212 is a better choice, I'll go that way. Thanks for your input!
Old 05-02-2003, 12:53 PM
nut11
nut11's Avatar
Post
I'm also very interested in the possibilities of using the Swepco 212. Theoretically, it should be ok, I'm assuming. Please advise.
85' Carrera Coupe 3.2
Old 05-03-2003, 12:46 AM
Chuck Harmon
Post
I have tried a couple of different tranny fluids, Redline, and Swepco 201. The 201 was better than the Redline, but 915 trannys tend to favor a non synthetic fluid so the Swepco was much better. I was reading a post on Pelicanparts about the 212, if you go to pelican and do a search Warren Hall has a post that really gives the low down on why 212 is a better choice than 201. Now this info mainly applies to high heat areas, like in the deep south, or racing applications.I find that my tranny shifts a bit smoother and my first gear is not quite as notchy, I have 248,000 miles on an origional tranny and I am fighting a rebuild. I change my tranny fluid every year as a precaution.
This may be over kill.... but anything I can do to make my car shift better untill I can afford the rebuild is a good thing !
Old 05-03-2003, 07:41 PM
Club Sport 911
Club Sport 911's Avatar
Post
I have 201 in my G50. some people say "don't / can't" whilst Swepco say "OK".... now here'es the dilema. I have a Club sport (i live in UK so it's EU spec) has an LSD, and I heard that 201 might prevent correct operation of the LSD. Could anyone confirm this ? - What it the best oil to help the notchy 1st to 2nd gear change ? - Swepco seems to do the trick....but @ what risk ?
Rgds
steve
Old 05-06-2003, 01:02 AM
Rob McKibbon
Rob McKibbon's Avatar
Post
<a href="http://www.pelicanparts.com" target="_blank">www.pelicanparts.com</a>
Old 05-06-2003, 02:40 AM
Matt Chamblin
Matt Chamblin's Avatar
Post
Any Swepco gear oil is like "Blue Magic". It works great.
Old 05-07-2003, 10:25 AM
Lane
Lane's Avatar
Post
Hi all, I used to sell SWEPCO. The differance between 201 and 212 is molybdenum sulfide, which is a moly additive. According to SWEPCO you may not want to use moly in some LSD trannys but 201 or 210 will work fine in LSD. I run 201 in my '79 930 with LSD, and my '88 G50 with no problems and both cars run DEs. SWEPCO 210 and 203 moly comes in multi-grade and single grade oils. SWEPCO 210 and 212 moly comes in only 80w/140 multi-grade oil.
Old 05-07-2003, 10:57 AM
kahuna
kahuna's Avatar
Post
Are there any different colors(varieties) of Swepco? I spoke w/ a local fellow that said something about red? 204?
Quick Reply: Where do you buy Swepco 201?
