Does anyone know the current draw for the front A/C condenser fan?
I just replaced this fan and installed an inline fuse as recommended by another on this board.
According to the Bentley manual, the circuit is 25 amp (circuit 2 of fuse block 1 for '88 Carrera). The circuit also includes the seat adjustment. I put a 25 amp fuse in the 14 gauge fuse assembly for now, but should the fuse rating be lower?
Or, is there a way to test the fan current draw?
TIA
Tony
TIA
Tony
If you don't have a VOM that can measure amperage up to 10 amps, purchase a common 0-25 amp analog panel meter. Place the meter in series with the load: meter in series on the positive wire to the blower motor (red/white wire is positive, brown is negative in the motor's wire harness).
Typical draw on the front motor is 4 to 5 amps.
http://www.allelectronics.com/make-a...l-meter/1.html
Team Owner
TIA
Tony
TIA
Tony
Also remember it wil peak out duing start up so see if the metr has memory with min max readings. and run the system through a few cycles to see what it peaks at .
The other much less techie way is keep reducing the fuse size and leave it for a week. See when it blows .. thats your peak current
