911 Forum 1964-1989
Suspension upgrade question for 82 SC.
Old 07-20-2006, 09:55 PM
SC4DnP
SC4DnP's Avatar
Default Suspension upgrade question for 82 SC.
I've been thinking aboout upgrading the sway bars on my 82 to the bigger Carerra bars. In the mean time I've found sway and torsion bars from an 86 torbo look. I don't know the sizes. I assume they would be bigger.
Sooo, anybody have any thoughts about this switch??
Old 07-20-2006, 10:57 PM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Hi:
The Carrera swaybars are larger so thats a good upgrade. Front torsion bars are the same as your SC's however, the rear Carrera bars are 1mm larger in diameter.
If you'll forgive me, I'd kindly offer that installing Carrera rear torsion bars are a total waste of good money for the VERY modest benefit weighed against the cost of installation, setup and alignment. If you truly want your SC to handle better, budget yourself for a set of torsion bars such as something in the 22/28 or 22/29 range. Now THAT makes a real improvement thats worth every dime,...
Old 07-21-2006, 01:42 AM
SC4DnP
SC4DnP's Avatar
Thanks Steve.
So go with Carerra sway bars and 22/ 28-29 torsion bars? Are the Turbo look tbars the same then as the standard Carerra bars? Does it make a difference that my SC is a Targa? I've got Koni adjustable shocks front and rear. I try to get to 2-4 track days a year other wise its my weekend toy. I still want my wife to enjoy the ride as well. Can I have my cake and eat it too?
Old 07-21-2006, 04:00 AM
Turbo-look Carrera's have 26mm rear torsion bars and 19mm front ones.
If you follow my recommendations for your Targa, I think you'll be very pleased with the results,......
Old 07-21-2006, 10:25 AM
SC4DnP
SC4DnP's Avatar
Hi Steve,
As allways you are the voice of reason and knowledge. I'll be looking for the Carerra bars. If I can't find OEM bars, is there an aftermarket source for them that you recomend? If so what size should I be looking for? Same question for the torsion bars. Is there a big difference between the 28 and 29 bars?
Thanks again for all your help and support!
Doug
Old 07-21-2006, 12:35 PM
The only aftermarket swaybars that we sell and install are the Smart Racing ones. Nothing else even comes close,....
Swaybar sizes are selected based on what & how you will use the car.
28mm or 29mm T-bars will both be OK with the nod going to 29's for DE events.
Old 07-21-2006, 01:25 PM
GothingNC
GothingNC's Avatar
I have the Sanders Hollow Torsion bars with Bilstein shocks on my 82 SC and love them
22MM F/ 28 MM Rear
Old 07-21-2006, 01:49 PM
mwildt
mwildt's Avatar
With such suspension change remember to get the car corner weighted and aligned too.
Steve is the guy! as always. He helped me many moons ago when I purchased some Bilstein shocks for my previous old '83 SC.
Michael
Old 07-21-2006, 03:16 PM
Doug&Julie
Doug&Julie's Avatar
Yoink. (..wanted to subcribe to this thread.. )
Old 07-21-2006, 03:52 PM
SC4DnP
SC4DnP's Avatar
Thanks Steve, and everyboby for your help and input.
Old 07-21-2006, 05:12 PM
Peter Zimmermann
Peter Zimmermann's Avatar
SC...: I'll add my two cents. Before you put the Carrera sway bars on have the rear mounting consoles replaced with the newer, stronger version. The bigger rear bar will break your consoles not long after you do the replacement.
Pete
Old 07-21-2006, 09:43 PM
SC4DnP
SC4DnP's Avatar
Thanks Pete,
I hadn't thought about that. What is it about those "bolt on" upgrades that always seem to be a bit more involved?
Cheers,
Doug
Old 07-21-2006, 10:00 PM
Rick964
Rick964's Avatar
WHen I bought my 80SC a few months ago my favorite wrench took me for a ride in three other SCs and Carreras with various suspension updgrades performed. My feel was that the 22/28 or 22/29 cars cornered much flatter but did not really feel that much stiffer on the roads - so you can have your cake and eat it, mostly.
Old 07-21-2006, 11:53 PM
SC4DnP
SC4DnP's Avatar
Thanks Rick. Thats one of the things I was curious about.
Old 07-22-2006, 12:27 AM
Rick964
Rick964's Avatar
Your welcome and I was quite surprised. After having been in a number of stiffened 964s and feeling how stiff they rode on the street I was shocked to see how this "inferior" torsion bar technology worked. If yu use the car a lot on the street (where your wife would car about it) then I would consider 22/28 or even 21/28. I use my car 80% for track and the 20% street is usually just me or with one of my kids so I think I will go 22/29.
Quick Reply: Suspension upgrade question for 82 SC.
