78 911SC - new owner questions
Just a few questions I am curious about:
1. Do I need to be concerned with the oil (OEL) level gauge ? Checking the dip stick level with the car warm and ideling the level (although hard to read since the oil is clean) seems to show proper oil level. However when car is cold on the oil level gauge it appears to be low and once the car is warm it shows in the upper range. Is this normal?
2. I have put a little over 1k miles since the oil service and the car used 3/4 of a quart of oil. Is this about normal? The car has no leaks, but I have read elsewhere on this board that some oil consumption is normal.
3. Lastly - now that the weather is getting warmer how do these car deal with the heat? Do they run hot??
Thanks in advance for your feedback.
Bill
Bill
Technical Specialist
Lifetime Member
Lifetime Member
Re: 78 911SC - new owner questions
1) The level shown on the gauge is only accurate when the car is sitting still and idling at temperature. Generally this gauge should not be trusted. Always check the oil with the dipstick.
Generally these cars run best with the level between the high and low mark. Keep it off the high mark or you may experience smoking from oil being sucked into the intake.
2) The rule of thumb is one quart every 1K miles is normal. Anything more should be investigated. Also be sure to use 20/50. As 3/30 is way to light for these cars and may cause you to use more oil.
3) It depends. Ambient temperature, rear wing (Cars with wings will run cooler on the highway), type of driving (Stop & go, highway or track). Bruce Anderson (Porsche Guru) always says that the normal range for these engines is 180-220, over 250 is unacceptably hot.
Welcome to the club!
Lifetime Member
Lifetime Member
Originally posted by Bill Gregory
If you scan the archives, you'll find where I've posted the current Porsche recommendations, which are predominantly synthetics.
My current thought is to put Mobile 1 15W50, since I mostly drive during the summer and live in California.
I run Mobil 1 15/50 in my '81 SC. Trust the dipstick -- when the engine is warm. My car (stock) does just fine dealing with very hot days.
Lifetime Member
Lifetime Member
I'm having trouble locating these recommendations actually.
models:
Manufacturer/Name Weight
Castrol/Syntec 5W-50
Exxon Superflo Supreme Spec . 15W-40
Mobil 1 5W-30, 10W-30, 15W-50
Sun Oil/Sunoco Synturo Gold 5W-40
Texaco/Havoline Formulat 3 Synth 5W-40
Valvoline/High Performance Syn. 5W-30
There has been an update to this bulletin, which I couldn't put my fingers on right now. The update incorporates 0w-40 and removes 15w-50, as I recall.
http://www.mobil.com/Canada-English/...il_1_0W-40.asp
http://www.mobil.com/Canada-English/...l_1_15W-50.asp
Now I feel like I need an oil education. For hot weather is 0W40 better than 10W30? 0W40 sounds like some sort of super oil.
I am running Castol GTX 20-50 non syn. The oil is mid way between the two marks with engine running at idle and warm. I was just concerned about the oil gauge since when the engine is cold after start up it is in the red zone. Once warm it is almost near the top, which almost equates to the level on the dip stick.
