Torque spec oil canister nut 1961 B Super Coupe
Gets guys, any advice on torque specifications? I feel like I've hammered it right but still leakage...... New gasket too.
Thank you!!!
Polar
Thank you!!!
Polar
Miserable Old Bastard
http://forum.porsche356registry.org/...torque#p180928
There seems to be no torque spec for the canister but a 356 expert advised 25lbs should be fine. I brought it to 25lbs and although it is better it's still not perfect. Just a bit running down the edge, before cranking on it more I'm getting paper gaskets to see if that works better...
