356 Forum 1948-1965
Emblem Placement
Old 03-13-2015, 05:28 PM
Edgy01
Poseur
Edgy01's Avatar
Default Emblem Placement
I want to restore the "Porsche" and "C" emblems to the back of my 1964 coupe. Does anyone out there know the critical placement instructions so that I can restore them to their proper positions?
TIA
Dan
Old 03-14-2015, 09:55 AM
Gerd
Gerd's Avatar
If you would o to porsche356registry.org/ they more information on their website very informative.
Old 03-15-2015, 06:00 PM
ralt12
ralt12's Avatar
If you look at the rear sheet metal from the back side (above the muffler), you'll likely see where the holes were filled in. If you're lucky, it was done with Bondo, and (after putting painter's tape on the outside of the car) VERY carefully work a very small drill or dental prod through the holes. A jeweler's file can work the hole open from there. If they're welded shut, you've at least got your measurements.
This is a lot easier to do, as well as badge reinstallation, if the motor is out of the car.
Old 03-16-2015, 01:52 AM
jcnesq
Miserable Old Bastard
jcnesq's Avatar
Here's a few data points from the 356 Registry. I don't think you can search if you aren't a member but you should join!
http://forum.porsche356registry.org/...cement+c#p1957
http://forum.porsche356registry.org/...ement+c#p81530
Old 03-21-2015, 10:59 PM
Edgy01
Poseur
Edgy01's Avatar
Thanks. As a 356 Registry member I will follow the link.
Also, how many studs are there supposed to be on the back of the PORSCHE emblem? I have seen some cars with just the holes there and see only two holes.
No bondo on this car. Everything welded up! (I already was hoping for that!)
Old 03-22-2015, 11:13 PM
jcnesq
jcnesq's Avatar
Looks like two studs for a C: http://www.stoddard.com/356-1/decals...59-301-06.html
Old 03-24-2015, 05:07 AM
Edgy01
Poseur
Edgy01's Avatar
Thanks! I guess I got the wrong one but since I'm not into the whole concour scene with my little bandito, it will be okay to put the 5 stud one on my C!
Quick Reply: Emblem Placement
