356 Forum 1948-1965
64c tach help
Old 10-29-2014, 11:13 PM
Hrvip Hrvip
Hrvip Hrvip's Avatar
Default 64c tach help
Hello!
'64 356c with 912 engine.
Tach doesn't work.
356c and 912 wiring diagrams both show an electronic tach.
Tach in car has mechanical connection.
Do I have wrong tach?
Now what?
Replace tach? Modify tach?
Thanks!
BK
Old 10-30-2014, 08:11 AM
Gerd
Gerd's Avatar
This site has much more information: porsche356registry.org
Old 10-31-2014, 08:16 PM
hkspwrsche
hkspwrsche's Avatar
You have a cable.
Old 10-31-2014, 08:19 PM
hkspwrsche
hkspwrsche's Avatar
After a new cable in my 64C and it snapped again, it seems the tach needs a rebuild. The resistance is stressing the cable. I'd recommend you rebuild the tach and replace the cable at the same time.
Old 10-31-2014, 10:00 PM
jcnesq
Miserable Old Bastard
jcnesq's Avatar
North Hollywood Speedo for repairs, highly recommended.
http://www.nhspeedometer.com/
Old 11-01-2014, 09:50 PM
Air Cooled Toys
Air Cooled Toys's Avatar
Early 356C cars had a mechanical tach and later C cars had the electric tach. You can change the set up where the tach connects to your 912 engine to have the gear-driven mechanical tachometer set up by sourcing the correct oil pump cover and gears:
The gears are shown here: http://www.stoddard.com/356-1/door-p...at=41&limit=60
Photos of this type of oil pump cover are here: http://postimg.org/image/x525m8pkl/
Quick Reply: 64c tach help
