Fuel Pump Needed 356A
I rebuilt the fuel pump best I could but it will not make enough pressure to fill the carbs. I think the pump valves are not holding pressure. What is the alternative that 356er's are using? New ones do not appear to be available.
many others do the same. if originality isn't a big deal the later B, C, 912 pump will bolt right on.
The owner of this 356 does not know what he wants to do with the car long term. It gets driven very little. He wants me to get it running again and he says he will run it more often. My thought is to have him turn off the fuel and run the carbs dry each time and install an electric pump. Does this make sense and could I install the electric inline with the weak original pump?
Miserable Old Bastard
It's easier to find used 356C / 912 pumps and they will work (make sure you have the right insulation block that goes with it. Zims also has good rebuild kits.
